Shapeoko #736 upgrade
PsyKo
Post by PsyKo » Sun May 12, 2013 11:37 pm
Hello folks,
It's been a while since my last visit here.
But here I am with an improved Shapeoko. The upgrades include :
- Dual X makerslide,
- Metal spacer,
- Metal V Wheels for X and Z axis,
- Longer rails (from 375 to 600mm)
- New Y end plates,
- New X end plates,
- Improved wire management.
I know that's a lot of updates, and I'm very happy with the result. Below is a couple of picture.
Unmounting the original Shapeoko
Painting the custom end plates (for both Y and X axis)
Final result
Shapeoko #736
PsyKo
Re: Shapeoko #736 upgrade
Post by PsyKo » Sun May 12, 2013 11:40 pm
Belt tensioner details
Y Axis belt tensioner
Metal spacer and V wheels
Shapeoko #736
PsyKo
Post by PsyKo » Sun May 12, 2013 11:45 pm
Cable chain
Result on a outlined aluminium plate
For the results of the improvement, it is GREAT. The result in aluminium is much better. It's possible to directly plunge into aluminium, double the depth of pass, milling faster and also a lot more space :)
I still have to redo the CNC bed.
For the tests, I created a real simple but effective pen holder :
Simple pen holder
I ran the Shapeoko Calibration pattern, and the result is below.
Shapeoko #736
PsyKo
Post by PsyKo » Sun May 12, 2013 11:49 pm
There are some artifacts, but this is me playing with the pen holder during the job :)
Calibration pattern. Pretty good.
Shapeoko #736
Post by WillAdams » Mon May 13, 2013 1:06 am
Looks great!
I wish I could justify new end plates --- almost done putting my machine back together --- ran short on belting, so need 2 longer eye bolts to make up the lack (added a note on the wiki).
Still need to work out cable management --- what size drag chain did you use?
PsyKo
Post by PsyKo » Mon May 13, 2013 5:07 am
The inner size for drag chain is 18 x 25mm. It's a little small given the 7mm diameter wire cable I'm using for the motors (4 x 1mm² + sheath). I managed to put in the cable for each motor + the spindle cable (4 wire in total)
Shapeoko #736
nio
Post by nio » Mon May 13, 2013 1:05 pm
Hi Psyko!!
good work with your machine!!!! looks awesome!!!
could you tell me where you buy aluminium spacers (in Europe???) or you did yourself???
Thanks...
PsyKo
Post by PsyKo » Mon May 13, 2013 3:22 pm
Hi nio,
Got them from HPC http://www.hpceurope.com/gb/
Shapeoko #736
Post by WillAdams » Mon May 13, 2013 3:33 pm
PsyKo wrote:Got them from HPC http://www.hpceurope.com/gb/
Excellent resource! I just added them to the Purchasing page as a ``Specialty hardware store'' --- does that seem okay, or should they be a ``Specialty vendor''?
The listing is:
HPC (Europe) --- site is available in English, French and Italian
Should anything additional be added or should they be moved?
PsyKo
Post by PsyKo » Mon May 13, 2013 4:56 pm
WillAdams wrote:Should anything additional be added or should they be moved?
It looks good to me
Shapeoko #736
