New TinyG aluminium enclosure
Hello folks,
I just spent a few days designing and creating the new enclosure for my future TinyG controller.
It's full aluminium, and build using 4 10x10mm extruded rails. All the panels have been milled using my Shapeoko.
The hole in the front panel is designed to have a front panel. It's been milled as well but it's not shown on the pictures.
Shapeoko #736
Re: New TinyG aluminium enclosure
Shapeoko #736
Shapeoko #736
Looks great!
Awesome!:)
A bit hard to get an overview as the pictures are kind of too big for my screen, but to me this looks as good as it gets..
Very nice work!
Very nice work!
Thanks for the comments
Right click on the picture >> Display image (at least in firefox) will give you the full picture.
Shapeoko #736
That is amazing! Almost brings a tear to my eye
ShapeOko hybrid, Dual X & Y Axis, ACME Z Axis, All NEMA 17, Kress 1050 FME-1 spindle (1.05KW), Steel V-Wheels & Hardcoat MakerSlide, Aluminum spacers, TinyG Controller, 800x550mm work area.
Excellent!!! Tu as utiliser quoi comme alu? Du 7075-T6 en 5mm? Et tu l'as usiner avec ta Shapeoko?
Shapeoko2 - Homemade CNC Control box - 400W/48V Chinese Spindle - Protoneer V3 Shield + DRV8825
Process - Illustrator > Makercam > UGCS
looks great, i just put a tinyg on my shapeoko 3 also. trying to get it up and running today.
Translation: Nice !!! What alloy did you use ? 5mm 7075-T6 ? Milled with the Shapeoko ?ArtFaks wrote:Excellent!!! Tu as utiliser quoi comme alu? Du 7075-T6 en 5mm? Et tu l'as usiner avec ta Shapeoko?
Yes it was completely milled using the Shapeoko (tuned shapeoko 1 in my case).
I'm not sure about the alloy since I used some scrap piece of aluminium. I know some were very soft and melt during process and some other (probably 2017/au4g) milled without issue.
Shapeoko #736
