New TinyG aluminium enclosure
PsyKo
Post by PsyKo » Sun Jul 28, 2013 8:59 pm
Hello folks,
I just spent a few days designing and creating the new enclosure for my future TinyG controller.
It's full aluminium, and build using 4 10x10mm extruded rails. All the panels have been milled using my Shapeoko.
The hole in the front panel is designed to have a front panel. It's been milled as well but it's not shown on the pictures.
The hole for the 4 motor wire connectors
Shapeoko #736
PsyKo
Re: New TinyG aluminium enclosure
Post by PsyKo » Sun Jul 28, 2013 9:02 pm
Ventilation grid
Wall attachements
Shapeoko #736
PsyKo
Post by PsyKo » Sun Jul 28, 2013 9:04 pm
First tests with chamfers. Home switches really helped a lot :)
Yeah... sometimes, things go wrong
Shapeoko #736
akhlut
Post by akhlut » Tue Jul 30, 2013 12:45 am
Looks great!
zerblatt007
Post by zerblatt007 » Tue Jul 30, 2013 7:45 am
Awesome!:)
A bit hard to get an overview as the pictures are kind of too big for my screen, but to me this looks as good as it gets..
Very nice work!
PsyKo
Post by PsyKo » Tue Jul 30, 2013 7:55 am
Thanks for the comments
Right click on the picture >> Display image (at least in firefox) will give you the full picture.
Shapeoko #736
tweak
Post by tweak » Sun Oct 06, 2013 7:38 am
That is amazing! Almost brings a tear to my eye ;)
ShapeOko hybrid, Dual X & Y Axis, ACME Z Axis, All NEMA 17, Kress 1050 FME-1 spindle (1.05KW), Steel V-Wheels & Hardcoat MakerSlide, Aluminum spacers, TinyG Controller, 800x550mm work area.
ArtFaks
Post by ArtFaks » Tue Jan 26, 2016 11:56 pm
Excellent!!! Tu as utiliser quoi comme alu? Du 7075-T6 en 5mm? Et tu l'as usiner avec ta Shapeoko?
Shapeoko2 - Homemade CNC Control box - 400W/48V Chinese Spindle - Protoneer V3 Shield + DRV8825
Process - Illustrator > Makercam > UGCS
JeromyReno
Post by JeromyReno » Wed Jan 27, 2016 7:23 pm
looks great, i just put a tinyg on my shapeoko 3 also. trying to get it up and running today.
PsyKo
Post by PsyKo » Thu Jan 28, 2016 7:27 am
ArtFaks wrote:Excellent!!! Tu as utiliser quoi comme alu? Du 7075-T6 en 5mm? Et tu l'as usiner avec ta Shapeoko?
Translation: Nice !!! What alloy did you use ? 5mm 7075-T6 ? Milled with the Shapeoko ?
Yes it was completely milled using the Shapeoko (tuned shapeoko 1 in my case).
I'm not sure about the alloy since I used some scrap piece of aluminium. I know some were very soft and melt during process and some other (probably 2017/au4g) milled without issue.
Shapeoko #736
