Built a quick laptop stand tonight!
Post by twforeman » Wed Feb 26, 2014 2:30 am
My co-workers were ribbing me about using two reams of paper to raise my laptop on my desk, so I decided to make a quick stand out of some 1/4" plywood. It's cheap plywood, so this is more of a proof of concept than a finished product, but I think it turned out okay.
I drew it up quick in LibreCad. The holes are just decorative, they have no function. It's about a simple as I could make it.
It took about 45 minutes to draw it up and then use CamBam to generate the toolpaths to mill it on my ShapeOko.
The holes took about 15 minutes to mill and the profiles were about 20 minutes.
Ender 3 3D Printer
Re: Built a quick laptop stand tonight!
Post by twforeman » Wed Feb 26, 2014 3:32 am
Here are the DXF and two g-code files for this stand, in case you are interested. The g-code for the holes in the stand makes a roughing and finishing pass, so it takes twice as long as it should...
Material to use is 1/4" plywood (baltic birch is best.) Tooling was a 1/4" two flute router bit.
type-1.pockets.nc
G Code for holes
(24.85 KiB) Downloaded 62 times
type-1.outsides.nc
G Code for outer profile
(17.69 KiB) Downloaded 54 times
type-1.dxf
DXF File for stand
(47.43 KiB) Downloaded 65 times
Ender 3 3D Printer
Gadgetman!
Post by Gadgetman! » Wed Feb 26, 2014 7:28 am
I notice that all your cross-connects are placed horisontally.
Consider adding a cross-connect in the back, or at least some sort of reinforcing at the joints, or the whole thing will one day collapse to one side, taking your laptop with it.
Looks good, though. ;-)
Nigel K Tolley
Post by Nigel K Tolley » Wed Feb 26, 2014 11:16 am
Probably easier to flip the rear lower crossbrace 90 degrees?
But yes, looks like it might fall under any sideways load. Depends how strong the glue is, I guess.
Looks great though.
Post by WillAdams » Wed Feb 26, 2014 11:45 am
Agree w/ rotating the lower rear cross-bar 90 degrees --- I'd also suggest rotating the lower front cross bar 45 degrees --- that would allow it to also hide cables &c. Or one could build the structure for a drawer into either the bottom or top.
Probably best to also put a pair of diagonal cross-braces at the rear w/ a half-lap joint to hold things securely.
Post by twforeman » Wed Feb 26, 2014 2:28 pm
Since it is designed for just holding the laptop at the same height as the monitor next to it and not for typing on, it's strong enough. There is only vertical load, no lateral.
I agree that it should have some cross bracing to stiffen it up, but it was just a quick proof of concept.
It is, however, stiffer than you might think. :)
Ender 3 3D Printer
wcritchie
Post by wcritchie » Wed Feb 26, 2014 5:17 pm
Looks great, I shall shamelessly steal your idea sir...
Sent from my XT1058 using Tapatalk
Tom Smith
Post by Tom Smith » Wed Feb 26, 2014 7:36 pm
Slick - the holes give it some visual interest, reminiscent of steel bridge, etc, construction :)
_______________
ShapeOko1 191
