Aluminum spindle mounts for Makita RT0701c
secretspy711
Re: Aluminum spindle mounts for Makita RT0701c
Post by secretspy711 » Wed Feb 25, 2015 3:20 am
Did you remove the Z plate and use that as a drill template for the aluminum mounts? Did you use the Shapeoko to drill those also, or a drill press?
One down, the other one is cutting right now. I added a flat opposite the clamp also.
The edges on your parts look decidedly cleaner than mine. I think this is because of the excessive runout on my DeWalt DW660's crappy collet...and is the primary reason I'm switching to the Makita!
makita mount.jpg (255.02 KiB) Viewed 2844 times
secretspy711
Post by secretspy711 » Sun Mar 01, 2015 7:33 pm
Got the Makita attached :D. Thank you criznach for posting the files to make the mounts, everything fit perfectly.
Something I didn't anticipate, since the Makita is so much shorter than the DeWalt DW660, was the extra distance created between the collet and the spoilboard. When the Z axis is lowered to where the bottom v-wheels are still barely on the makerslide, there is still nearly 2 inches between the collet and the spoilboard. Most of my bits don't protrude that far, so I will have to raise up the work surface when cutting thin materials or deep pockets. I suppose a 3rd, middle set of v-wheels on the Z axis would help solve this also.
Anyway, my TIR went from .010"+ on the DeWalt, to .002" on the Makita, so I'm happy!
I made the extra-clearance Z-plate from .250" stock aluminum, cut down to .160" for each of the 2 pieces. I cut these with the Makita when the original z plate was still installed. Comparing the results to other aluminum I've cut, I can already see better results from the lower runout. There is much less cutter wandering and chattering, especially on the ramp-down on triangular holding tabs.
Caesar S
Post by Caesar S » Sun Mar 01, 2015 8:52 pm
Hey that's neat! May I order 1 already tapped and drilled (ready to mount)?
Thanks, Caesar.
criznach
Post by criznach » Sun Mar 01, 2015 11:19 pm
Nice work! I don't have time to make any mounts lately, but maybe someone else is up for it?
secretspy711
Post by secretspy711 » Mon Mar 02, 2015 6:06 am
I don't have enough aluminum to make any more, and they are time consuming... Not to mention drilling the holes was "interesting" since I don't have a drill press -- I used the shapeoko. Spiral milling works ok but the clamp hole needed a real drill bit due to reach. Problem is, the spindle goes WAY too fast for straight drilling and I ended up with powdered aluminum and a very dull bit!
Sent from my Nexus 6 using Tapatalk
criznach
Post by criznach » Mon Mar 02, 2015 5:39 pm
Yeah I forgot to say I used a drill press. I did make some clamp-on jigs to get the hole positions correct. That helped...
UnequalTech
Post by UnequalTech » Sat Apr 04, 2015 1:42 am
Is anyone able to make me a set of these?! I'm ugrading my Shapeoko 2 and would love to tighten up my Makita with some aluminum spindle mouints. I've got a drill press
Shapeoko 2 #?? w/Makita RT 0701C
kristenanne77
Post by kristenanne77 » Mon Feb 13, 2017 6:47 pm
I went to github and the file is not a dxf file. It is a htm file that my VCarve program cannot read.
How do I get the dxf file?
K
Post by WillAdams » Mon Feb 13, 2017 7:35 pm
You have to click through until the text of the DXF is displayed:
https://github.com/trailhead/shapeoko-s ... 0mount.dxf
Then click on the "Raw" button to get the link:
https://raw.githubusercontent.com/trail ... 0mount.dxf
criznach
Post by criznach » Mon Oct 23, 2017 5:45 pm
Is there still interest in these? I have a set that I just need to drill and tap. I sell them for $80 usd + shipping.
