VCarve Bar Sign
criznach
Re: VCarve Bar Sign
Post by criznach » Sat Mar 15, 2014 7:53 pm
RobCee wrote:
ztil wrote:Searched they forums, but could not find a vcarve plugin. Is it called something else?
They call it VEngrave and you can grab it here
Sorry I hadn't checked this thread lately and missed your question. VEngrave is right. The only gotchas I've found with VEngrave:
  • Set the "Max Crossover Distance" to a very small value like 0.01, or the plugin will drag your v-bit through the material between close-together shapes.
  • Letters with a hole in them, like "O", or "e" need to be converted to regions. Select both parts inside and out, and convert to region.
