Made some aluminum parts for a 3d printer
groguard
Post by groguard » Sat Apr 26, 2014 8:44 pm
First off I want to say this is the first time Ive milled some aluminum, and I have to say I was impressed with the results. More of the info I needed to cut these I pulled off the forums and the wiki, so most of the credit goes to the shapeoko community for making it happen without blowing something up. Today I made some replacement parts for a friends 3d printer. I milled a modified version of the maxstruder for a mendel v1.5. Its the extruder body and the idler arm. Here is my results
Settings
500mm/min feed
100mm/min plunge
.2mm step down
2 flute center cut end mill(from inventables)
accuracy was +/-.2mm over 3inches
6061 1/8" thick aluminum
and 6061 3/8" thick aluminum
Shapeoko 2 #3920. Nema 23's. Belt drive Z axis, ACME rod upgrade,
1m rails on X and Y, X upgraded to 60x40 extrusion with openrail, Mid span supports,
DW660 with Super-Pid, IC's DW660 dust shoe.
Build Log
Re: Made some aluminum parts for a 3d printer
Post by WillAdams » Sat Apr 26, 2014 9:16 pm
Looks great! Do you know which alloy of aluminum it was?
groguard
Post by groguard » Sat Apr 26, 2014 9:23 pm
WillAdams wrote:Looks great! Do you know which alloy of aluminum it was?
Thanks! Its all 6061 aluminum :)
Build Log
Post by cvoinescu » Sun Apr 27, 2014 12:39 am
That looks very, very nicely machined. Congratulations!
To me, that looks like an extruder with a NEMA14 motor (or maybe I have the scale wrong and you have a boss hole larger than 22 mm, or maybe it's a geared NEMA17). The part on the left will have a spring and a bearing attached to it and will press the filament against the drive wheel, and the part on the right will be bent 90 degrees to make the body of the extruder (the lower cut-out is a J-Head-style hot end mount). Am I way off?
groguard
Post by groguard » Sun Apr 27, 2014 12:45 am
cvoinescu wrote:That looks very, very nicely machined. Congratulations!
Thanks for the comments on the quality! Yes you are correct, the larger hole is for a geared nema 17, and the part on the left will have a spring and a bearing and attach as you described. He is going to be bending and tapping the other parts himself.
Here is a picture that I pulled from Makers Tool Works of what it should look like assembled. It is a MendelMax V2 extruder body that has been modified to work with a MendelMax V1.5
http://cdn1.bigcommerce.com/server3200/ ... 00.jpg?c=1
Build Log
Nigel K Tolley
Post by Nigel K Tolley » Sun Apr 27, 2014 10:48 am
That's nice. Is that with the stock spindle?
groguard
Post by groguard » Sun Apr 27, 2014 5:35 pm
Nigel K Tolley wrote:That's nice. Is that with the stock spindle?
Im using the Dewalt DW660
Build Log
danimal
Post by danimal » Mon Apr 28, 2014 11:59 pm
The 6000 aluminum alloys are the toughest to mill in my experience. They seem to rub and contact weld much easier than the 7000 or 2000 alloys. With that said your parts look fantastic, did you use any cooling or lubrication?
Shapeoko # 1458
groguard
Post by groguard » Tue Apr 29, 2014 12:19 am
danimal wrote:The 6000 aluminum alloys are the toughest to mill in my experience. They seem to rub and contact weld much easier than the 7000 or 2000 alloys. With that said your parts look fantastic, did you use any cooling or lubrication?
I used whole lot of WD40 lol :)
Build Log
kmoller
Post by kmoller » Wed Feb 11, 2015 8:20 pm
Hi
do you have the drawing , for the idler arm ? , I am i building , a mendelmax 2 3d printer , and i cant find the drawing for the idler arm!! , and i came across your post while googling
Br.
Kenneth Moller , Denmark
