3/8th in. Aluminum DWP611 Mounts
TonyB
Post by TonyB » Mon May 12, 2014 5:55 pm
I designed some DWP611 Mounts to be cut out of 3/8 6061 Aluminum. I bought a sheet of 1 ft. x 1 ft. x 3/8 in. from a random vendor[sp]on eBay[sp]for rougly $32 to my door.[br>It took about two hours to cut one mount. I used a 1/8th carbide endmill that I bought from[sp]drillman on eBay. My specs were, target depth: 4mm, step down: 0.2mm, feed rate: 240mm/min, plunge rate: 20 mm/min.[br>(Because I'm using Mach3; I choose a conservative[sp]feed/plunge rate, since Mach3 has functionality to increase and decrease these rates while the job is running.)
dwp611.svg.txt
(7.89 KiB) Downloaded 351 times
410whp/411ftlbs
Build Thread
Woodworker
Re: 3/8th in. Aluminum DWP611 Mounts
Post by Woodworker » Mon May 12, 2014 11:05 pm
What was it designed in an would you consider posting? I'm attempting to keep my options open for a spindle and if I have brackets, then I can test before I lock myself in.
Simon P
Post by Simon P » Tue May 13, 2014 8:49 am
Having just been down the same road, albeit in HDPE, I have to say I like how you've incorporated a locating lug in the mount using the milled groove on the router body. Also impressed that you are tackling aluminium - what spindle did you use to cut it?
Shapeoko 2 #3697 - Dewalt D26200 Spindle, Precisebits Collets, 250mm Z-Axis Makerslide
Schruminator
Post by Schruminator » Tue May 13, 2014 1:03 pm
Those are some good looking mounts-- nice!
TonyB
Post by TonyB » Tue May 13, 2014 2:19 pm
Woodworker wrote:What was it designed in an would you consider posting?
I drew it in Inkscape. I can post the file; does anyone know how to upload SVG's?
(as a side note: I'm thinking of grinding off the two inner tabs, on the top bracket. That would allow the top bracket to be mounted higher, giving more Z axis depth.)
Simon P wrote:Having just been down the same road, albeit in HDPE
I'm curious to know whether doing aluminum was really worth my time?
I know HDPE is going to be softer, but would it be soft enough to create backlash? The two reasons I went with aluminum where: 1. Rigidity, 2. It looks good (It matches my Z axis plate and my bearing blocks, since I cut my own for these).
Simon P wrote:I have to say I like how you've incorporated a locating lug in the mount using the milled groove on the router body.
Thanks, though I got the idea from someone else... lol
This was version 2 of my design. After seeing this:
http://www.shapeoko.com/projects/project.php?id=64
I decided to change my original design (which was two pieces).
Simon P wrote:Also impressed that you are tackling aluminium
Milling aluminum was my original requirement to building a Shapeoko. I planned (and really haven't yet) to build stuff for my car project. I did build a few things for my motorcycle, however.
The biggest complaint I have about aluminum, is mill time. One bracket took 2 hours to mill! I took a day of vacation from work and cutting two brackets consumed about 8 a.m. to 3 p.m. Hopefully I can refine the process and work on other things while it's milling.
Simon P wrote:what spindle did you use to cut it?
A DW660.
Schruminator wrote:Those are some good looking mounts-- nice!
410whp/411ftlbs
Build Thread
Post by WillAdams » Tue May 13, 2014 2:38 pm
TonyB wrote: I drew it in Inkscape. I can post the file; does anyone know how to upload SVG's?
rename the file to <filename>-svg.txt and then upload it.
TonyB
Post by TonyB » Tue May 13, 2014 4:16 pm
410whp/411ftlbs
Build Thread
scott216
Post by scott216 » Wed May 14, 2014 4:53 pm
You could upload to Thingiverse. It's the perfect spot for something like this. And it makes it easier for people to find.
Shapeoko v2 with DW660
GRBL v0.9i
scott216
Post by scott216 » Wed May 14, 2014 4:56 pm
TonyB wrote: Milling aluminum was my original requirement to building a Shapeoko. I planned (and really haven't yet) to build stuff for my car project. I did build a few things for my motorcycle, however.
I haven't done any aluminum yet but I want to try some soon. What settings did you use to mill these brackets?
GRBL v0.9i
Simon P
Post by Simon P » Wed May 14, 2014 5:50 pm
Hi Tony,
I have no means of quantifying the flex in the Z axis yet and obviously I have only ever had my Dewalt 611 in HDPE mounts. From visual and haptic observation it feels as stiff as the dremel ever did in it's aluminium 'universal' mounts. I have observed that I get a lot more flex by torquing the whole carriage around the X-axis makerslide than I do from the HDPE mounts - any contribution to flex at the router bit from them is negligible. I'm keeping my eyes open for a decent test indicator which I can use to take some comparative measurements and hopefully hone in on where improvements can be made. I think it is actually the V-wheel assemblies that are the weakest link in terms of backlash at the bit now and improving on them would be quite a lot of rework. I could be wrong, but that's what it seems like.
Simon
