Cut the TOOL wrench out of aluminum.
groguard
Post by groguard » Sun Jun 29, 2014 2:30 am
Hey guys, I haven't post anything in a while so I figured I would show you what I did today. I decided today I was going to cut out the TOOL wrench
for my girlfriend as she is a big TOOL fan. I figured since its a pretty simple design I would just make my own DXF. I used Inventor to design it, and
CamBam to get everything setup. Its 1/8" 6061-t6 aluminum, I used a Niagara C330 1/8" 3 flute TiAlN coated end mill. I didnt use any coolants or
cutting oil. My settings .2mm DOC 650mm/min feed 100mm/min plunge. Took a little over an hour to do the whole job. Its 281mm long 135mm wide.
Here are some pics
Build Log
Re: Cut the TOOL wrench out of aluminum.
Post by WillAdams » Sun Jun 29, 2014 11:12 am
For those who are curious, TOOL is a heavy metal band, and the (intentionally) rather phallic wrench is their logo.
Considered editing the title of the post, but decided not. If anyone is offended or troubled, make a separate thread and we can work it out.
Nigel K Tolley
Post by Nigel K Tolley » Sun Jun 29, 2014 12:35 pm
Very amusing. And nicely made.
Woodworker
Post by Woodworker » Sun Jun 29, 2014 2:05 pm
Interesting logo. Was there much cleanup needed on the piece or was it mostly burr free? I see a lot of brackets and such, it is good to see some aluminum cut for other purposes.
groguard
Post by groguard » Sun Jun 29, 2014 5:59 pm
WillAdams wrote:For those who are curious, TOOL is a heavy metal band, and the (intentionally) rather phallic wrench is their logo.
Yes, if you guys feel its inappropriate I will remove it.
Woodworker wrote:Interesting logo. Was there much cleanup needed on the piece or was it mostly burr free? I see a lot of brackets and such, it is good to see some aluminum cut for other purposes.
As far as the cleanup goes I just took a sanding block to all the edges to make sure they weren't sharp. Other than that it was pretty much good to go right out of the machine.
Build Log
Woodworker
Post by Woodworker » Sun Jun 29, 2014 6:27 pm
Excellent, thanks for posting the speeds and feeds also.
