Aluminum Baseboard
McMagical Eng.
Aluminum Baseboard
Post by McMagical Eng. » Wed Aug 06, 2014 5:39 pm
This was a shop project I created to make a super sturdy base for my Shapeoko2. I wanted to use coolant on my cutting projects, but the MDF threaded wasteboard became a sponge and warped once the coolant leaked onto its surface. I also really like the MDF threaded pattern with the clamps, but I found that I wanted more holes for small and odd shaped project clamping. I used the template for the MDF board and made a 13x13 grid for the holes. The board is solid 6061 aluminum (1/2") milled flat and drilled to mill spec. Each of the 167 holes is was drilled, tapped for M5 bolts, and then chamfered.I still plan on running a circle polish bit over the grid to get a scaled polish finish.
More project photos can be found on the mods page here: http://www.shapeoko.com/projects/project.php?id=115
Shapeoko2 NEMA 17s, Custom aluminum baseboard, coroplast sideskirts, 300W quiet cut spindle, 3d printed enclosure, panel on/off, E-stop
"They took from their surroundings what was needed... and made of it something more." -Primer-
Re: Aluminum Baseboard
Post by cvoinescu » Wed Aug 06, 2014 6:11 pm
Beautiful overkill!
CastIrony
Post by CastIrony » Thu Aug 07, 2014 6:51 am
Ok, now I'm jealous.
eklipseone
Post by eklipseone » Mon Dec 01, 2014 10:41 pm
are you selling these?
chomdh
Post by chomdh » Sat Dec 13, 2014 6:46 pm
Way cool.
Shapeoko2 #3702:
