This is my first go at creating a Edge Lit Plexiglass sign for a friends daughter celebrating her 4th birthday.
I milled the plexi using a 60deg v-bit for the graphic of hello kitty I then used a diamond tipped spring loaded engraving bit to etch her name into the heart. I then milled the base as a 3D milling job first cutting the top slot then doing a profile milling operation to mill out the base half way through the wood as I did not have a bit to mill all the way through. I then flipped the board and milled out the bottom to fit the electronic and widened the slot for the plexi at the bottom to hole the LED lights. I then did a second profile operation to cut the rest of the way through the wood to finish the base. I then milled a piece of aluminum to act as the bottom cover put it all together and this is the final result....
Base Side View
Base Top View
Sign complete
Edge lit Plexiglass Night Light
Re: Edge lit Plexiglass night light
......Here is the night light lit up
Night light turned on Note in this image the small ring on top where the plexi enters was not there, I added the upper ring to the base to further hide the led lights below.
Re: Edge lit Plexiglass Night Light
That is cool; I hope she likes it!
Shapeoko 2 # 6651: 500x1000mm, Acme screw and belt drive Z-axis, DW660 w/ IC mount, Arduino/grblShield w/ gCode 0.9g and 3D-printed electronics enclosure.
It looks awesome. Great job!
Shapeoko 2 - CNC Shield & TinyG - 400w spindle - (Sketchup -> CamBam -> GCode Teleporter)
My Software: GCode Teleporter - GCode Truncater
http://www.thingiverse.com/philc
Where did you get the spring loaded engraving bit, or is it something you custom made? I want to start working on similar projects, so I want to be ahead of the curve when I start.
Thanks,
Allan
Thanks,
Allan
ShapeOko2, serial ??
DW660 spindle;
Upgrades: 900mm X axis and 1000mm Y axis; ACME Z Axis; modified MDF wasteboard with t-slot
Primary usage: wood crafting (signs, plaques, and ultimately a CNC-made electric guitar)
DW660 spindle;
Thanks for the positive comments ...
@Allan - I got the bit off of ebay you can see it here, make sure you get a spring loaded one....
http://www.ebay.com/itm/151402216873?_t ... EBIDX%3AIT
I see this is an older post. But you've had luck. I'm trying to mill plexiglass as well. What are your feeds and speeds, if you don't mind sharing?
-IzumI-
Shapeoko 2 : With Works Kit and 1000mm Expansion
Upgrade with X-Carve, Acme Screw kit, and X-Controller
