Aluminium engraving - front panel
PsyKo
Post by PsyKo » Mon Oct 13, 2014 5:19 pm
Hello folks,
I've been running some test on alupanel (HDPE layer caught between 2 0.3 aluminium sheets) in order to do a front panel for my enclosure.
Worked pretty well, but had to fill the toolpath with paint to give higher contrast.
0.5mm 0.8 1 flute endmill
200 mm/m
0.2 mm/pass
Edit : fixed endmill size from 0.5 to 0.8mm
Below are the results :
From right to left : 0.3 45° engraving V-bit, 1.5mm 2 flutes endmill, 0.8mm 1fulte endmill
End results
Shapeoko #736
Schruminator
Re: Aluminium engraving - front panel
Post by Schruminator » Mon Oct 13, 2014 6:17 pm
That looks pretty slick. And a 0.5mm endmill is awfully tiny-- did you have any issues with breaking or bogging it down?
PsyKo
Post by PsyKo » Mon Oct 13, 2014 6:40 pm
Yeah, I broke one running it too fast. I first tried at 400mm/min. It broke after a few seconds. Slowing it down to 200 did the trick.
Your message made me realize it was not 0.5mm but 0.8mm endmill. First post edited
Shapeoko #736
msg558
Post by msg558 » Thu Oct 16, 2014 3:23 pm
Looks really good. What was your method for filling the toolpath with paint?
PsyKo
Post by PsyKo » Thu Oct 16, 2014 3:54 pm
It's actually pretty simple :
1. Spray it with paint so the toolpath is fully covered.
2. Wait a few seconds, something like 30 for me (maybe not necessary)
3. Whipe the panel with a dry cloth. At this point there will be some paint smudge.
4. Remove the remaining paint with a cloth "humidified" with thinner. The paint in the toolpath should stay.
Shapeoko #736
zerblatt007
Post by zerblatt007 » Fri Oct 17, 2014 7:49 am
Very nice result.
But if you have to paint it anyway, is it any point in using the sandwich panel instead of solid aluminium?
Is it cheaper?
PsyKo
Post by PsyKo » Fri Oct 17, 2014 12:20 pm
zerblatt007 wrote:Very nice result.
Is it cheaper?
You're right. There is no reasons to use the sandwich panel. I tried this because I though that the HDPE would look dark black and wouldn't require paint. I was wrong.
Actually it was kind of dark-grey and the result is much better with paint. So the next one will be in aluminium panel.
This was a free sample, so I have no idea of the price compared to aluminium. It's for sure lighter.
Shapeoko #736
