An afternoon with aluminum
dottore
Post by dottore » Thu Jan 01, 2015 3:02 am
My earlier experiment with 303 got me thinking about how to maximize tool life, and how I got much better results when I used more of the axial surface of the end mill.
I have another project lined up that I've been sort of dragging my feet on, because it involves removing quite a lot of aluminum — basically pocketing out the inside of a 4" x 4" x 1" piece of aluminum. The last time I cut something out of aluminum was a second spindle bracket for the Makita, out of 12mm plate. That was a three step operation:
  • Roughing out the inside of the bracket: pocketing, 1/4" end mill, 0.6mm depth of cut at 900mm/min
  • Roughing out the outside of the bracket: slotting, 1/4" end mill, 0.5mm depth of cut at 600mm/min
  • Finishing the entire thing: outside profile with a little bit of slotting, 1/8" end mill, 0.5mm depth of cut 500mm/min
At these material removal rates, I was going to be sitting at the mill for something like six hours... so now you see why I was dragging my feet.
This morning I thought I'd set up a little bit of a challenge to apply some of the stuff I've been thinking about with regard to tool engagement to cutting aluminum. So my challenge was this: cut a pocket in 6061, 25mm x 25mm square with 6.35mm radiused corners, 7.5mm deep, as fast as possible.
To keep everything else constant, I worked up a toolpath in SolidWorks and HSMXpress, and kept it the same for each experiment: adaptive clearing (trochoidal path) with a helical entry at 350mm/min.
The way I would normally do it has a 8m40s runtime: 2.54mm tool load (think "stepover," but held around corners), 0.6mm depth of cut, 900mm/min.
So my first experiment was to run a 0.5mm tool load, 2.5mm depth of cut, 1,700mm/min at 10K RPM. Here's what happened.
This is definitely not a happy Shapeoko... but it didn't break anything either. The spindle is noticeably deflecting (it's especially bad at the extremes in Y). The finish at the bottom of the pocket wasn't acceptable to me — it had a fair bit of distortion as a result of the spindle twisting.
I then did a whole bunch of stupid stuff that isn't worth talking about, like rapiding 10mm straight down into the piece of stock.... :lol:
I tried adjusting the tool load down to 0.25mm, but that didn't help very much. Decreasing the feed rate down to 1,200mm/min wasn't very helpful either. After a little bit more experimenting, I figured two things out (maybe obvious):
  • The only way I could control the spindle deflection was with reducing the feed rate. The existing gantry carriage system just does not have enough rigidity to drive the spindle quickly through aluminum. I think....
  • The Makita RT0701CX speed control is limited, in that the motor can't apply full power at low RPM. Tweaking the spindle speed up to around 15K RPM made things work out better.
That got me to a test run at 0.5mm tool load, 5.0mm depth of cut, 600mm/min at 15K RPM. Success!
A 2.5mm pocket on the left and a 5.0mm pocket on the right, same cutting parameters:
There is one bit of deflection fairly early in the expansion of the 5mm pocket, which I think is due to chip buildup. (It is very hard to get all the chips out of the small pocket, as the video makes very clear!) Surface finish was absolutely acceptable to me for a roughing pass. This path would take 5m19s for the pocket... but maybe I can do better.
0.5mm tool load, 7.5mm depth of cut (yup, full depth), 450mm/min at 17.5K RPM: let's make some chips.
And what a lot of chips it is:
The surface finish is, again, totally acceptable. I'd want to run a finishing end mill over it, but it's completely acceptable for a roughing pass. This would complete my challenge in 3m51s, which is half the time I started with.
I think a 3/16" 3-helix aluminum rougher would provide even better performance. I could more efficiently use the higher RPM range with the spindle, which should let me increase the feed rate (at the expense of decreasing tool load, but it's a net win). A end mill with chip breakers would help deal with chip build-up.
I think that given how most people seem to use Shapeokos (basically CNC routers, with mostly slotting operations) this is not a useful technique. Chip clearing is a major problem, and deep slots are very challenging. However, if you are doing an operation where you can get the chips out of the way (pocketing, outside contouring, etc.), and you can generate a suitable toolpath, this method shows some promise.
Re: An afternoon with aluminum
Post by cvoinescu » Thu Jan 01, 2015 3:50 am
Most impressive!
RobCee
Post by RobCee » Mon Jan 05, 2015 2:20 pm
This is extremely impressive and good use of experimentation. Thank you for sharing it!
It does go to show how important the high pressure flood coolant you see in large mills really is for clearing the chips.
Hans
Post by Hans » Mon Jan 05, 2015 3:35 pm
What did you use for coolant? It looks clear... is it WD-40?
Shapeoko #1,123
tbfleming
Post by tbfleming » Mon Jan 05, 2015 7:12 pm
Very nice!
dottore
Post by dottore » Wed Jan 07, 2015 1:16 am
Hans wrote:What did you use for coolant? It looks clear... is it WD-40?
It's Kool Mist 77, diluted as directed (4 oz to 1 gallon of water). A gallon of concentrate is about $40 so it's much cheaper in the long term than WD-40 or cutting fluid. Much safer for humans, too. ;)
It's actually blue, but when fed through the mist system it comes out a sort of pale blue-white emulsion.
danimal
Post by danimal » Tue Jan 20, 2015 10:31 pm
One other thing that I found with a little trial and error (mostly error) is that radius end mills help with aluminum. I am not sure why, but my machine sounds like it is on its last legs getting ready to blow up with a standard end mill, and I throw on a radius end mill and run the same cam file and it was much smoother. I think it has something to do with the way that the chip is initiated with a rounded edge that causes less vibration and deflection. I tried it with two different sizes, and had pretty much the same results.
Great write-up by the way.
Shapeoko # 1458
