AtomSoft
Post
by AtomSoft » Fri Jul 20, 2012 12:43 am
Ok now that the AtomCNC is made... i need to make a case... any ideas on how where to start?
I made my board in Solidworks with the terminals,power & usb for reference... Its all exact measurements (or i hope
I used a digital caliper to take measurements and create the terminal, usb, power and reset button. It all seems to fit into place without having to scale anything so i assume its all good.
- atomcncsolid.jpg (40.41 KiB) Viewed 4549 times
- solidcnc.jpg (49.56 KiB) Viewed 4550 times
Blog /
Store
Live to Love, Not to Hate.
Do you like the help i give? Think i deserve a tip?
DONATE
AtomSoft
Post
by AtomSoft » Fri Jul 20, 2012 6:05 pm
It coming along:
- caseR1_alm.jpg (60.4 KiB) Viewed 4496 times
Blog /
Store
DONATE
AtomSoft
Post
by AtomSoft » Sat Jul 21, 2012 1:54 am
Even more work done... i just need to make the fan holes and reset hole and it will be complete... i think
- caser1_sf.jpg (47.54 KiB) Viewed 4465 times
Blog /
Store
DONATE
AtomSoft
Post
by AtomSoft » Sat Jul 21, 2012 2:22 am
Ok take a look now... Any Thoughts????
TOP:
- TOP.jpg (58.22 KiB) Viewed 4462 times
ISO:
- ISO.jpg (80.29 KiB) Viewed 4462 times
Blog /
Store
DONATE
AtomSoft
Post
by AtomSoft » Sun Jul 22, 2012 3:05 am
Going to HomeDepot tomorrow. Need some acrylic... i guess i should really stock pile the stuff
Blog /
Store
DONATE
CptanPanic
Post
by CptanPanic » Sun Jul 22, 2012 11:36 am
2 questions. One how are you going to cut the holes for the tabs with square inside corners, and do you think there's enough material outside of the holes to be strong?
AtomSoft
Post
by AtomSoft » Sun Jul 22, 2012 3:15 pm
CptanPanic wrote:2 questions. One how are you going to cut the holes for the tabs with square inside corners, and do you think there's enough material outside of the holes to be strong?
Ok ,
1) The square holes will appear to be square if i use a smaller bit
2) thanks for telling me about the edge... didnt realize how thin it was. ill extend them
Blog /
Store
DONATE
AtomSoft
Post
by AtomSoft » Sun Jul 22, 2012 3:46 pm
Ok :
- newiso.jpg (82.17 KiB) Viewed 4382 times
- expl.jpg (57.86 KiB) Viewed 4382 times
- isowtop.jpg (60.32 KiB) Viewed 4382 times
Blog /
Store
DONATE
AtomSoft
Post
by AtomSoft » Sun Jul 22, 2012 4:53 pm
With PCB Texture:
- isotext.jpg (53.88 KiB) Viewed 4378 times
Blog /
Store
DONATE
