Shapeoko electronics enclosure and a bookshelf
jhllt67
Post by jhllt67 » Sun Jul 22, 2012 8:31 pm
Hey guys finally got my dual drive set up (I used a drive shaft, might make a post about it later) and the shapeoko is running great.
Here are a couple of projects I messed around with this weekend.
First is an enclosure for the power supply, arduino, cut-off switch etc.
Not populated yet, I actually have to cut another one because I accidentally made it about 1/8" to small for the power supply. :oops:
Made out of 5mm sanded birch plywood.
Next is just an interesting idea I had for a mini book shelf.
Made out of 3/8" rough plywood, just a prototype for now. I'm gonna add one more level but that seems to be the stability limit for this design.
No glue or fasteners yet, I just made the slots about .01" undersize, seems to work pretty well.
Here it is on the test bed.
baz
Re: Shapeoko electronics enclosure and a bookshelf
Post by baz » Mon Jul 23, 2012 10:56 am
Hi,
These are great projects, I really like your book shelf design.
Also definitely post something about your dual drive shaft set-up.
Regards
Baz
ShapeOko #676, eShapeOko #11, Hardened MakerSlide, OpenRail, Steel v's, Misumi Extrusion, Kress 800
MakerSlide Europe Store
esacteksab
Post by esacteksab » Mon Jul 23, 2012 8:40 pm
Awesome! Also interested in the drive-shaft setup.
LOVE the bookshelf idea. Did you increase the size of the Shapeoko?
Serial # 215
jhllt67
Post by jhllt67 » Mon Jul 23, 2012 11:07 pm
Hey thanks guys. I'll definitely make a post about the drive shaft when I get home for the week. Probably Wednesday.
And yeah I did extend the Y axis to 1200mm. You may be able to fit it on a standard Shapeoko if you go corner to corner. I think the brace is about 12 inches long.
