Early tests with different materials
rocnik
Post by rocnik » Sat Jan 24, 2015 10:51 pm
Hi,
Here are some of my early tests with different materials and software.
Aluminum.
Done with 1 mm endmill
Feedrate 240 mm/min
Just 0.1 mm depth increment.
Aluminum
Bakelite
1/8" endmill
Feedrate 500 mm/min
Depth increment 0.5 mm
Bakelite
Particleboard
Software used Halftoner 1.4
45° V-bit
Particleboard
Shapeoko 2 #6318 stock size + ACME Z Axis upgrade
Arduino Uno + CNC shield V3.0 + A4988 drivers. grbl 0.9g
rocnik
Re: Early tests with different materials
Post by rocnik » Sat Jan 24, 2015 10:54 pm
Rubber
1.5 mm endmill
500 mm/min feedrate
Rubber
Rubber 2
Some more particleboard
Software used F-engrave
45° V-bit
particleboard
clockit
Post by clockit » Sat Jan 24, 2015 11:08 pm
nice work! really digging the batman one!
Shapeoko 2, Full Kit #7071, Makita RT0701C Router, 1000 x 1000 upgrade, Acme Z Axis w/Nema 17 Belt Drive
blueshorts
Post by blueshorts » Sun Jan 25, 2015 1:17 pm
Fantastic job! I'm curious as to how many and what kind of flutes were on the endmills you used (where applicable).
Shapeoko 2 #3217 with an acme threaded rod and belt drive z axis, proxxon IBS\E spindle, NEMA23 motors on all axes, and a tiny g controller.
halfnormal
Post by halfnormal » Sun Jan 25, 2015 4:25 pm
Great work on the rubber. What type of rubber and what bit did you use? My wife is a crafter and I would love to make her some custom stamps.
rocnik
Post by rocnik » Sun Jan 25, 2015 9:46 pm
Aluminum Generic chinese 1 mm 2 flute endmill
Bakelite 3.175 mm 2 flute endmill from drillman
Rubber left one 1.5 mm generic chinese 2 flute endmill
right one 0.8 mm 2 flute endmill from drillman
All endmils with spiral flutes
Rubber is some semi hard rubber which I had at home. Really don`t know any spec of that rubber.
blueshorts
Post by blueshorts » Mon Jan 26, 2015 2:47 am
Thanks for the info! Aluminum is on my to do list and every piece of information helps.
Sent from my iPad using Tapatalk
