GeoCaching Container
Damin69
Post by Damin69 » Thu Mar 12, 2015 5:46 pm
I have been into Geocaching for many years. Fell in love with it. As a young teen my dad and I would got hunting but as I got older we hunted less and Less and I have not hunted in well over 20 years now. GeoCaching was a way for me to get back into the woods but for a completly different hunt. Now I take a GPS and Camera with me searching for Tupperware, Ammo Cans, etc. And with all of this the caches I really like to find are the Unique caches. Those that are not common. I like caches that are a challenge or that have great camouflage. I also have like to make creative caches. Now that I have the CNC this opens up a whole new possibilities for creativity.
Here is the latest cache I just created. It is a type of puzzle cache you have to figure out how to open it by twisting the container that slides a pin through a hidden path that is created by openings in disks that I cut with the CNC and pieced together with 3m bolts.
It all started with an Idea I had one morning when I was waking up. I tossted it on paper.
I then moved to creating interchangable disks in Autocad they are all .25 inches thick. So I knew I needed 12 of them to create a 3 inch puzzle. There is one large center hole that holds a Bison Tube/Pill container that holds the Cache LOG.
I then took that file into Cambam to create my Gcode.
Then on to cutting that all out.
Then to Assembly
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
Brian Stone
Re: GeoCaching Container
Post by Brian Stone » Thu Mar 12, 2015 5:57 pm
Nice work. That is too cool.
Shapeoko 2 #7353
CastIrony
Post by CastIrony » Thu Mar 12, 2015 6:13 pm
Is that acrylic?
Damin69
Post by Damin69 » Thu Mar 12, 2015 6:15 pm
CastIrony wrote:Is that acrylic?
No it is 1/4" HDPE. You can buy full 4'x8' sheets of HDPE at HomeDepot. They stock 1/4" black was like $55 bucks.
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
Post by WillAdams » Thu Mar 12, 2015 6:33 pm
Damin69 wrote:No it is 1/4" HDPE. You can buy full 4'x8' sheets of HDPE at HomeDepot. They stock 1/4" black was like $55 bucks.
Doesn't seem to be listed on-line: http://www.homedepot.com/s/hdpe%20plastic?NCNI-5
I see 48 x 96 x .118 black acrylic --- $132.99ea. http://www.homedepot.com/p/Unbranded-48 ... /202653706
1/4" clear is $178
I did find: 1/16 in. x 4 ft. x 8 ft. Plastic Panel $19.98: http://www.homedepot.com/p/PLASTEX-1-16 ... /202090190
Fastenal lists 0.25" x 48" x 96" Black High Density Polyethylene Sheet at $279.08 ea.: https://www.fastenal.com/web/products/details/0955086
Don't hold out!
I'm currently buying: http://www.therestaurantstore.com/cutti ... 18245.html and http://www.therestaurantstore.com/18-x- ... 18241.html
Damin69
Post by Damin69 » Thu Mar 12, 2015 6:35 pm
1/4" clear is $178
Don't hold out!
Oh Crap I am so sorry.. NOT HomeDEPOT.. it was Menards
4'x8' sheets http://www.menards.com/main/p-2246284-c-14048.htm
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
Post by WillAdams » Thu Mar 12, 2015 6:45 pm
Damin69 wrote:Oh Crap I am so sorry.. NOT HomeDEPOT.. it was Menards
's alight. Appreciate the information --- that's a great price --- I may be able to justify going to the Ohio fountain pen show after all....
coyn0839
Post by coyn0839 » Fri Mar 13, 2015 1:03 am
That looks neat.
I also want to thank you for pointing out that Menards sells HDPE. I didn't realize it. I already spend too much money there...what's a few more dollars hahaha
Shapeoko 2 #8311\1800mm x 1000mm rails\ACME Z axis upgrade\DW660\loc-line dust collection system
Post by edwardrford » Fri Mar 13, 2015 4:28 am
Damin - That looks great.
I noticed the utility knife in one of the pictures. Is that what you were cutting the tabs off with? If so - that's what I used to do until I started using a small chisel (1/4" irwin from menards).
Now, when I make my tabs, I make them 3/16" (5mm) wide, then when the parts are done, I take the sheet off, set it on my bench, line up the chisel with the tab, and then give it a solid wack with a rubber mallet. For square parts it works so well that I don't need to scrape anything else off. For round parts, it works, but not as great because of the radius.
Either way - great work on the cache container. Really cool project.
side note: the HDPE at my Menards is in the same isle as the MDF and 'exotic' (not OSB) plywoods.
Damin69
Post by Damin69 » Fri Mar 13, 2015 4:51 am
edwardrford wrote:Damin - That looks great.
Thanks Edward. Yup I use my utility knife for just about everything. I will have to look at using 1/4" sometime. My tabs are are usually .12" unless I am working on anything bigger.
HDPE is in same isle as the Hardwood ply also.
Thanks,
Todd
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
