More OrdBot Parts
Will Winder
More OrdBot Parts
Post by Will Winder » Mon Aug 06, 2012 12:51 am
I picked up a couple cheap plastic cutting boards from Walmart this week and got around to cutting parts today.
I was cutting at 1000 mm/min with the dremel set to 7-8. Here are some pictures.
Colecago
Re: More OrdBot Parts
Post by Colecago » Mon Aug 06, 2012 2:10 am
Is your goal to turn your CNC into a dual purpose cnc/printer? That would be awesome.
Will Winder
More OrdBot Parts
Post by Will Winder » Mon Aug 06, 2012 1:50 pm
I'm making a separate 3d printer and manufacturing some of the parts with the CNC machine.
Will Winder
More OrdBot Parts
Post by Will Winder » Thu Aug 30, 2012 11:36 pm
Here is the first of two idler plates. This is the first time I've successfully milled aluminum. A dremel worked fine using a 1/8" bit, but immediately broke a 1mm bit.
My current upgrades are dual-y motors and moving the belts to the outside, my guess is only the dual-y is required for milling aluminum.
Karl
Post by Karl » Fri Aug 31, 2012 1:10 am
Nice!
What was the depth and speed when milling with 1/8" bit? Did you use any fluid?
http://www.akafugu.jp
ShapeOko #313
Will Winder
Post by Will Winder » Fri Aug 31, 2012 12:29 pm
Feed was 300mm/min, depth increment 0.4, no cutting fluid.
The job took about 5 minutes and when it finished the bit wasn't even warm.
Karl
Post by Karl » Fri Aug 31, 2012 4:11 pm
Thanks.
What kind of bit? Flutes etc..
ShapeOko #313
Tom Smith
Post by Tom Smith » Fri Aug 31, 2012 4:28 pm
Pretty slick, Will!
I think I need to re-evaluate my cutting speed/approach. I get more of a melting effect, it seems, than the blizzard of chips that I see in your plastic cutting images above - I am feeding at 800mm/min, and my old craftsman rotary tool speed is maxxed out. I think I read that too slow a speed causes the melting, perhaps this old tool just can't hack it? I am using a 2 flute ballnose, maybe that is the problem...what kind of bit are you using for these cuts?
I am also getting oval shaped circles due to flex from the left side of the gantry (and perhaps the spindle mount), I need to finish my driveshaft asap. Really interested in milling aluminum at some point!
Thanks,
Tom.
_______________
ShapeOko1 191
Will Winder
Post by Will Winder » Fri Aug 31, 2012 4:51 pm
I'm using this bit for the aluminum:
http://www.ebay.com/itm/1-8-1250-2-FLUT ... 58958aa037
I'm not sure what I was using for the plastic, I must have gotten lucky with those settings since the blizzard is how it came out on the first try.
Will Winder
More OrdBot Parts
Post by Will Winder » Sat Sep 01, 2012 1:46 am
I made a couple more parts today, this is the only one that needed modifications. The original was designed for nema 14/17's and I have 2 extra 23's.
Both of these failed half way through. For some reason Grbl reset, I'm not sure why. Fortunately it was after the outer profile had been defined so I finished cutting it out with my stationary jigsaw.
