Engraving leather
marcooostendorp
Engraving leather
Post by marcooostendorp » Sat Jun 20, 2015 3:46 pm
Probably I am not the only one who thought about ‘engraving’ leather. Since there is no topic about this I will share my experiences here.
Engraving leather works but it is very precise work, 0.01 of an inch too deep and it looks ugly. A first trail with various depths thought me that 0.01 inch is deep enough, going any deeper will lead to loose edges. Especially small pockets, for instance in the a and e, are sensitive to tearing of the top layer of the leather.
As leather is a natural product it is not evenly thick which leads to problems. I solved this by putting slight pressure on the wasteboard with my hands when it seemed like the shapeoko hit a thicker part.
Not surprisingly: hard leather yield cleaner cuts than soft leather.
And last but not least: leather seems to dull your bit very fast.
leer bewerken.jpg (178.45 KiB) Viewed 1252 times
clockit
Re: Engraving leather
Post by clockit » Sat Jun 20, 2015 4:33 pm
I would have never thought to engrave on leather... nice little project and looks amazing! Thank you for sharing and I learned something today... it's a good day, keep the projects coming!
Post by WillAdams » Sat Jun 20, 2015 5:01 pm
\begin{graphicdesignPSA}
Please, don't use all caps w/o consideration of the ornateness and spacing of the font.
\end{graphicdesignPSA}
For more on Zapfino: http://www.tug.org/TUGboat/tb24-2/tb77adams.pdf
Cutting and working w/ leather was an impetus to my working up a drag knife design. I've been meaning to get back into leather working.If nothing else the pounding is therapeutic.
TomO
Post by TomO » Sat Jun 20, 2015 9:38 pm
Very cool - I'm sure I will give this a try eventually. Thanks for sharing.
Xaracen
Post by Xaracen » Sun Jun 21, 2015 12:12 pm
Very nice, I think I'll give that a go when I get a suitable bit of leather to try it on. I suspect it isn't amenable to the sort of fine detail I can get on copper or slate, given leather's ability to flex out of the way more easily than copper can, which was a problem I met in a recent project. I am surprised at the mention that leather can rapidly dull the engraving bits.
Shapeoko v1 #????
500mm Y-slides with dual Y-steppers
375mm dual X-axis gantry
150W DC ER11 Sable2015 spindle
conductive probe via spindle shaft/toolbit (can probe while spinning!)
Arduino Uno running grbl v0.9i with grblShield v4.
