3D relief carving
derrak
3D relief carving
Post by derrak » Wed Jun 24, 2015 6:24 am
My first 3D relief project with Shapeoko 3 (SN#75) and ChiliPepper. My wife and I were scanned at our local science museum, OMSI, by a company called JoeScan, who makes laser scanners mainly for the logging industry. I downloaded the stl, cleaned it up in Blender then imported it into MeshCam where the gcode was generated. Overall runtime was about 5.75 hours carving into a chunk of walnut. The height of the cut is 22CM, depth ~2CM.
The tool change, from a .25" upcut to a .125" ball went very well in ChiliPepper with the aide of a touchplate.
Finished output:
Roughing pass output:
For scale:
I have since cleaned it up with a Dremel with flap wheels, but haven't had a chance to finish it yet. I may post an update when it's complete.
MeshCam Settings.png (283.69 KiB) Viewed 5872 times
SmokyRick
Re: 3D relief carving
Post by SmokyRick » Wed Jun 24, 2015 11:01 am
Now that is really cool !!
graycon
Post by graycon » Mon Jun 29, 2015 2:45 pm
Looks neat. Reminds me of Han Solo.
dick_deck
Post by dick_deck » Wed Jul 15, 2015 3:43 pm
This is pretty cool. I use MeshCAM myself, and could never figure out how to do tool changes. However, I also use UGS. What is your method for doing tool changes?
Woodworker
Post by Woodworker » Wed Jul 15, 2015 7:50 pm
Not sure how meshcam works but I just export the Gcode code for one tool, such as engraving, in a file, let the file run, hit the return to zero, raise the spindle and change tools. Rezero manually and load the profile file and run it.
CastIrony
Post by CastIrony » Wed Jul 15, 2015 8:50 pm
We should make a group of Portland area Shapeokos.
GoSpeedRacer
Post by GoSpeedRacer » Thu Jul 16, 2015 12:26 am
Seems to be a few of us haha
(not quite in the club yet tho hahaha)
dick_deck
Post by dick_deck » Fri Jul 17, 2015 9:08 pm
Woodworker wrote:Not sure how meshcam works but I just export the Gcode code for one tool, such as engraving, in a file, let the file run, hit the return to zero, raise the spindle and change tools. Rezero manually and load the profile file and run it.
Hmm, OK. I just discovered one of the reasons I'm having such trouble with this is that it appears UGS does not recognize the tool change command, and just moves on. I just started trying ChiliPeppr, which pauses at the tool change command, throws up a window, and lets you swap the bit.
The OTHER tidbit I realized (a little late unfortunately) is that the plastic collars on the bits are so you can put them into the chuck at the same depth. :oops:
These two pieces were the missing links that caused me to give up on tool changes. Hopefully some other noob can benefit from my eureka. :P
dorf_online
Post by dorf_online » Wed Aug 26, 2015 5:10 pm
I'd be up for a Portland Shapeoko group!
Shapeoko 3, not yet running anything other than makercam... I have many questions and I think I want to move onto meshcam or something else, Want to bounce some questions off people using meshcam.
Manicska
Post by Manicska » Mon Sep 07, 2015 2:44 am
Good job your first carving! To clean it up, I would recommend a smaller stepover. I used a 40% (.05 mm) stepover for my first 3d carving and it turned out pretty decent. It will take longer of course, but the result will be well worth it.
@ 40% with a .125 (1/8) ballnose
