My first cuts. (Letters for wall)
rcpongo
Post by rcpongo » Tue Aug 25, 2015 4:47 pm
Here is my first project, keeping my daughter happy. These are cut out of foam because I figured it would be a nice material to do my initial tests on, with less worries about things like being too aggressive and breaking a bit.
My very first cut. Went way too slow with my settings, but it came out great.
By the 3rd letter I had my speeds down. And check out that depth!
Reverse side showing how thin.
rcpongo
Re: My first cuts. (Letters for wall)
Post by rcpongo » Tue Aug 25, 2015 4:48 pm
The final results.
All the letters
First coat of paint
RobCee
Post by RobCee » Tue Aug 25, 2015 4:52 pm
Very nice looking and a great way to learn.
rodcar125
Post by rodcar125 » Tue Aug 25, 2015 5:21 pm
Those look great!
Wondering if you could use the foam to dip them a little bit in paint an transfer the shape onto a wall
rcpongo
Post by rcpongo » Tue Aug 25, 2015 6:39 pm
This is actually a dense hard foam, not a soft sponge foam, so I'm not sure how well it would work for that.
It's been a great material for cutting though. The details are incredibly sharp, and it cuts very quickly.
sraney
Post by sraney » Wed Aug 26, 2015 12:03 am
Looks nice. I have someone asking me to do something similar with a bit more detail across the Z axis. Could you elaborate on the foam, bit, and feeds and speeds you used for that foam?
rcpongo wrote:Here is my first project, keeping my daughter happy. These are cut out of foam because I figured it would be a nice material to do my initial tests on, with less worries about things like being too aggressive and breaking a bit.
-- sraney
  • break nothing but silence
  • take nothing but pictures
  • leave nothing but footprints
rcpongo
Post by rcpongo » Wed Aug 26, 2015 3:44 am
still working on what speeds I can use. I had no problems at all with 650 for the speed and 5mm depth per pass though. I had my dw611 set around 3 for the speed.
the foam is an insulation board that can be found at a hardware store. I get the blue stuff at Lowes, and Home Depot and Menards has the same thing in Pink. You can get it in different thicknesses, 1 inch, 2 inch,...I think there might be a 3/4 inch. Anyways, it's about $20-30 for a 4 foot x 8 foot sheet, so it lasts a long time. I use it to cut wings for RC planes, and now with the shapeoko I hope to cut some wings and fuselages from it soon.
sraney
Post by sraney » Wed Aug 26, 2015 5:37 am
Thanks for the info, I'll have to see if I can locate some at the Lowes next door.
rcpongo wrote:still working on what speeds I can use. I had no problems at all with 650 for the speed and 5mm depth per pass though. I had my dw611 set around 3 for the speed.
-- sraney
