Simple Under-Cabinet Wine Rack
dave_the_nerd
Post by dave_the_nerd » Mon Oct 19, 2015 2:13 am
Made an under-cabinet wine rack today. (Replacing the other one in the picture - we apparently have to have completely empty kitchen counters now for some reason.) First project I've done since enlarging my S2 to 500x1000mm, and it used pretty much the whole length of the thing.
Cut it out of an oak 1x10, so the brackets are 3/4" thick. The flat pieces on the counter are just some scrap, and will be hidden by the lip of the cabinet.
I rounded off the faces with a roundover bit on the routing table. Still have to do finishing work (glue, sand, stain, poly).
DW660, 1/4"x1" Niagra 3-flute TiAN-coated cutter, 0.04" step, 40ipm. Easy going, didn't seem to stress the cutter/spindle much.
Pattern attached if you like it.
WineRack-2.svg.txt
svg file (remove .txt)
(1.63 KiB) Downloaded 168 times
Shapeoko 2 # 6651: 500x1000mm, Acme screw and belt drive Z-axis, DW660 w/ IC mount, Arduino/grblShield w/ gCode 0.9g and 3D-printed electronics enclosure.
Re: Simple Under-Cabinet Wine Rack
Post by WillAdams » Mon Oct 19, 2015 11:17 am
Very nice!
Since it wasn’t posted in the projects area on the main page, I added it to the wiki.
dave_the_nerd
Post by dave_the_nerd » Fri Oct 23, 2015 2:21 am
Here's a picture of it installed. Still needs to be finished but that's the housemate's job. (I build 'em, she paints 'em.)
AnonymousPerson
Post by AnonymousPerson » Fri Oct 23, 2015 10:13 am
Looks good. :)
