New Makita Mounts
Damin69
New Makita Mounts
Post by Damin69 » Sun Nov 29, 2015 3:36 pm
For awhile now I have been wanting to make new mounts for my makita. I wanted to move my router out away from the gantry just a little bit to give me a little more clearance for a new dust shoe. I also knew I wanted to make them out of aluminum. So I have been watching and reading on speeds and bits and finally was brave enough to try aluminum again. I designed my bracket so I could use a 1/4" bit instead of an 1/8" bit since I was going to be milling through 1/2" matrial I wanted a beefier bit to do the work.
I am using a 2 flute carbide endmill, Makita up to 4.5, .002" depth per pass at 25ipm on the first bracket. took 4.5 hours. On the second one I decided to bump the feed rate to 30imp and it took 3.5 hours shaved a whole hour off.
In the end I am super impressed on how they turned out. I just need to drill and tap and get installed today.
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
xfredericox
Re: New Makita Mounts
Post by xfredericox » Sun Nov 29, 2015 3:43 pm
very clean!
http://www.manmademayhem.com
RobCee
Post by RobCee » Mon Nov 30, 2015 8:52 am
Wow! Those look really great. Very clean cuts on them.
Hofy
Post by Hofy » Mon Nov 30, 2015 5:55 pm
I was very impressed watching them get cut out.
Shapeoko 2 #8123 Makita 0701 with aluminum mounts, Nema23, ACME Z Axis with Nema 23 Belt drive.
JeromyReno
Post by JeromyReno » Mon Nov 30, 2015 6:04 pm
nice!!!
PollyMotion
Post by PollyMotion » Mon Nov 30, 2015 10:25 pm
Great project, great result! :)
Did you use any coolant while milling it? Oil, or similar?
-- PollyMotion
Damin69
Post by Damin69 » Mon Nov 30, 2015 10:32 pm
PollyMotion wrote:Great project, great result! :)
-- PollyMotion
When had started with a little wd 40 made about 2 passes then I stopped using it. I have to stop about 20 min cause realized I had forgotten to put a tab in on the chunck of alum in the center and did not want it flyhing out and breaking anything. When I stopped I check the bit and it was as cool as it had been when I started so I just let it go. I ran the entire second bracket with zero fluid and after 3.5hour bit was still cool.
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
