Mid Span Supports
bharbour
Mid Span Supports
Post by bharbour » Sat Dec 26, 2015 5:35 pm
I recently upgraded my stock SO2 to 1000mmX1000mm and I made myself a couple of X axis mid-span supports out of ABS plastic sheet. I am surprised at how much rigidity the ABS supports provide. I intended to have three bolts per rail instead of the two, but I ran out of post assembly insertion nuts.
I can provide the Inkscape file if anyone is interested. I actually took the end plate drawing and modified it into the mid span support.
ajacocks
Re: Mid Span Supports
Post by ajacocks » Mon Dec 28, 2015 4:03 am
bharbour,
I'd like to see the Inkscape files. I'm in the process of upgrading my S2 to a 1000mm^2 X-carve, and I'd like to add a set of mid-span supports, while I'm building it.
Alex
Shapeoko 2 #3250
bharbour
Post by bharbour » Mon Dec 28, 2015 9:03 pm
Will get those to you tonight.
ajacocks wrote:bharbour,
Alex
WanderingFool
Post by WanderingFool » Wed Mar 09, 2016 6:03 pm
I'm interested in the inkscape files too!
Doug
Shapeoko 2 #5066, build in progress
matthewtmead
Post by matthewtmead » Mon Nov 07, 2016 10:06 pm
I'm about to upgrade to 1000mmx1800mm on my Shapeoko2 and would love to get the inkscape files too. thanks!
bharbour
Post by bharbour » Tue Nov 08, 2016 9:23 pm
PM me your email and I'll send to you...tnx,
matthewtmead wrote:I'm about to upgrade to 1000mmx1800mm on my Shapeoko2 and would love to get the inkscape files too. thanks!
trevor
Post by trevor » Sun Dec 11, 2016 3:15 am
Do you still have those files for the midspan support. I would love to make a a set for my shapeoko. Thanks!
