Sorta ready for Xmas
ijv
Post by ijv » Sat Jan 09, 2016 11:26 am
These are some jewellery boxes that I was making as Christmas presents. I has them cut out in time at least, but finishing had to wait till afterwards. The wood is pine and finished in 2-3 coats of Scandinavian Oil. One thing I found out the hard way is that you should pay attention to the fine print on the instructions, when it says to wipe off, you need to do just that otherwise it takes ages to dry.
The profiles were cut using 1/8in 2 flute end mills, using a feed rate of 1000 mm/min @ 12,000 rpm and 0.75mm DOC, while for the pockets I used a 18mm 2 flute router bit with a feed rate of 750mm/min @ 12,000 rpm and a 0.5mm DOC. I'm using the Inventables 300W spindle which I find pretty nice, but I want more power!!
One problem I ran into was chattering and a rough finish when cutting out the main body with a 30mm long 1/8 end mill (1000 mm/min feed rate & 0.75mm DOC) does any one have any recommendations for feeds and speeds for this situation?
cheers,
ijv
AnonymousPerson
Re: Sorta ready for Xmas
Post by AnonymousPerson » Sun Jan 10, 2016 12:46 am
They look nice. :)
ijv wrote:... I used a 18mm 2 flute router bit ...
Do you have the link handy for where you bought the 18mm router bit? I've been using a 10mm end mill for roughing out things, and haven't yet seen larger stuff that's affordable, which will fit in my spindle. 18mm sounds like it would clear stuff fairly quickly. :)
ijv wrote:... does any one have any recommendations for feeds and speeds for this situation?
There are "feeds and speeds" calculators around (including free), which might help: :)
http://www.shapeoko.com/wiki/index.php/ ... Calculator
Shapeoko 3 #516
ijv
Post by ijv » Sun Jan 10, 2016 5:02 am
They look nice
Thanks, my daughters think they look nice as well, but that didn't stop them from decorating them with stickers and the like. :D
I'm in Australia, I got the bit at the local big box hardware store.
http://www.bunnings.com.au/ultra-6-4-x- ... t_p6373247
cheers,
ijv
AnonymousPerson
Post by AnonymousPerson » Sun Jan 10, 2016 3:58 pm
ijv wrote:Thanks, my daughters think they look nice as well, but that didn't stop them from decorating them with stickers and the like. :D
Kids. :D
ijv wrote:I'm in Australia, I got the bit at the local big box hardware store.
Thanks, that makes tonnes of sense. I should be able to find something locally or on Amazon along those lines. :)
Shapeoko 3 #516
