Booze/wine rack
AnonymousPerson
Re: Booze/wine rack
Post by AnonymousPerson » Sat Jan 16, 2016 11:46 am
Hmmm, I used to use Illustrator CS5 (few years ago), and I'm pretty sure it had that feature then. ;)
Shapeoko 3 #516
xfredericox
Re: Booze/wine rack
Post by xfredericox » Mon Jan 18, 2016 6:40 pm
you can round corners but it rounds all the corners of the selected shape. You can't select 2 lines and only change the enclosed corner, as you would in any CAD program.
So it is pretty much a useless feature in earlier versions.
unless I miss something but i've looked...
http://www.manmademayhem.com
TomDChi
Re: Booze/wine rack
Post by TomDChi » Wed Jan 20, 2016 3:46 am
The fillet "handle" rounds all the selected corners. If you use the filled in selection arrow tool to select a rectangle, then the whole rectangle, including all of its corners are selected, and dragging the fillet "dot" will round all those corners. If you switch to the hollow selection tool and only select one of the corners of the shape, then only that fillet "dot/handle/anchor" will appear, and dragging it will effect only that one corner. (Of course, you can select multiple individual points and then fillet them as a group.)
