Vacuum Table!
cowtheory
Re: Vacuum Table!
Post by cowtheory » Wed Feb 17, 2016 6:55 am
I made a vacuum table based on your design and cut out the pieces from 6mm thick MDF boards. However, I got poor suction results. It doesn't seem to be able to hold even a piece of paper. I am currently using a normal household vacuum cleaner (1400 Watts). Is that not enough power? How much wattage should I look for in a vacuum cleaner? Thanks
AnonymousPerson
Re: Vacuum Table!
Post by AnonymousPerson » Wed Feb 17, 2016 5:50 pm
Just as a general thought, from my recent vacuum pump experimenting (not a vacuum table yet though)...
Do you have any kind of sealant around that you could plug up any non-useful gaps?
It's amazing how much air can get through very small (tiny) gaps, ruining the suction. As I've been finding out recently. ;)
If you haven't done it yet, even just covering every seam you can find with layers of tape might help.
For something a bit more permanent, maybe some form of gasket sealant?
http://www.amazon.co.uk/V-tech-Black-Si ... B00442NWOQ
(yeah, this is the completely ghetto approach :>)
Shapeoko 3 #516
cowtheory
Re: Vacuum Table!
Post by cowtheory » Thu Feb 18, 2016 1:50 am
Thanks, I'll give that a try :)
jkanzaki
Re: Vacuum Table!
Post by jkanzaki » Mon Mar 07, 2016 7:56 am
HI all,
Does anyone know what program open up c2d?
I use cambam, and makercam both software cannot open c2d
thanks
Shapeoko 1 - dissassemble
AnonymousPerson
Re: Vacuum Table!
Post by AnonymousPerson » Mon Mar 07, 2016 10:46 am
Pretty sure it's "Carbide Create", the new basic intro thing from Carbide 3D.
Haven't tried it myself, but it's here if that helps:
http://carbide3d.com/dl/
Shapeoko 3 #516
Re: Vacuum Table!
Post by WillAdams » Mon Mar 07, 2016 12:47 pm
Yep:
edwardrford wrote: using Carbide Create to design a vacuum table we've been talking about for a long time now.
jkanzaki
Re: Vacuum Table!
Post by jkanzaki » Mon Mar 07, 2016 4:47 pm
AnonymousPerson wrote:Pretty sure it's "Carbide Create", the new basic intro thing from Carbide 3D.
Kyleitzen
Re: Vacuum Table!
Post by Kyleitzen » Wed Apr 20, 2016 5:25 am
Here is some information on my Vacuum Table. Made from two layers of 1/2" Baltic Birch. 16"x17" overall dimensions. 12"x12" vacuum work surface. 1/4" grid pattern milled into the bottom. 1/4" diameter holes on one inch. Added 1/8" grid in between holes to increase clamping force. Cheap Home Depot Bucket Head Vacuum.
It's used to hold Rowmark engraving plastic in place while being milled and engraved. Works great!
SO3: Mods: baltic birch worksurface, vacuum table
Primary use: plastics engraving, name tags
www.ItzenSigns.com
LTEPM
Re: Vacuum Table!
Post by LTEPM » Mon Aug 08, 2016 2:00 pm
Any updates on improvements to the table design?
How small of parts will this hold?
Hurumph
Re: Vacuum Table!
Post by Hurumph » Tue Jul 18, 2017 11:19 pm
edwardrford wrote:Hi All,
If you're interested in making one of your own, here are the c2d files (one for top, one for bottom)
vacuum_table.zip
If you do make one of your own, send us a picture (sales@carbide3d) with the subject of 'vacuum table'. if you're one of the first 10 pictures we get, we'll send you a free 1/4" cutter for being awesome.
It doesn't seem like the entire design is there in the zip file you attached. The only thing that shows up for me is a single hole for the hose attachment and then a grid of circles on the top piece. I'm using carbide create, but am I doing something else wrong? I wanted to try your build as a starting point and then tweak it as I go along.
