E85 conversion Aluminum projects
TonyB
Re: E85 conversion Aluminum projects
Post by TonyB » Wed Mar 09, 2016 4:20 pm
Couple more things. I changed radiators as I felt my fans were running more often then they should. Making more horsepower should produce more heat, so solving that issue seemed like a good idea.
I then came to find out that the last adapter I made (this radiator is meant for a mkIII Supra, not a mkII) set the radiator about an inch too high.
New unbent vs. old:
New bent and installed:
Fits perfect on the first try!:
I'm getting good at getting the dimensions extremely precise. I invested in a 4 inch micrometer, a 6 inch micrometer, a 12 inch micrometer (highly recommend this one!), and a set of inside mics. Probably spent less than $100 on all this; well worth the money!
410whp/411ftlbs
Build Thread
JeromyReno
Post by JeromyReno » Fri Mar 11, 2016 7:32 pm
Looks good. Love the look of raw welded aluminum
