Makita mounting brackets
xfredericox
Post by xfredericox » Tue Nov 22, 2016 7:16 pm
Made new Makita mounting brackets:
http://www.manmademayhem.com/?p=2325
2016-11-21 16.08.55.jpg (321.84 KiB) Viewed 1445 times
2016-11-21 15.41.14.jpg (319.74 KiB) Viewed 1445 times
Re: Makita mounting brackets
Post by WillAdams » Wed Nov 23, 2016 4:41 am
Excellent!
I need to finish working up mounting a 65mm mount I bought off eBay...
zerblatt007
Post by zerblatt007 » Wed Nov 23, 2016 9:16 am
Really nice work!
I might try to make this one to use with my spare Makita in case the Kress poops out at the wrong moment.
Your link has an extra 2 at the end: http://www.manmademayhem.com/?p=2325
zerblatt007
Post by zerblatt007 » Wed Nov 23, 2016 10:03 am
Your Linear Slide CNC Router Actuator is pretty sweet http://www.manmademayhem.com/?p=2199
But it is almost 2Kg. How is that compared to your old parts?
xfredericox
Post by xfredericox » Wed Nov 23, 2016 4:17 pm
thanks for the kind words
and thanks for catching that link mistake.
It may be heavier, but everything is mounted closer to the rail, and I reinforced it. All things considered I'd recommend it in a heartbeat!
bharbour
Post by bharbour » Wed Nov 23, 2016 4:43 pm
Cool...was the SVG created in Inkscape? When I bring it into Inkscape, it's seems a little small.
xfredericox
Post by xfredericox » Thu Nov 24, 2016 10:04 am
Nope, designed in rhino, exported to illustrator and made the svg from there.
But dimensions are 92x75mm, which would make the circle 65,5mm across
Damin69
Post by Damin69 » Sat Nov 26, 2016 4:06 am
Vert nice looking mounts. I will probably cut new ones when I go to install new C-Beam Linear actuator I ordered today.
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
xfredericox
Post by xfredericox » Sun Nov 27, 2016 12:20 pm
Here's the final listof all upgrades.
Now I need fun projects again!
http://www.manmademayhem.com/?p=2361
