Han Solo trapped in Delrin?
Post by Improbable Construct » Thu Oct 04, 2012 2:58 am
I have some scrap delrin laying around so I milled Han Solo into a piece.
This chunk is about 2" x 3.5".'
Milled with a 1/16" ball nose bit
800 mm/min feed speed
10% step over.
photo (1) (Medium).JPG (137.15 KiB) Viewed 3699 times
photo (Medium).JPG (206.51 KiB) Viewed 3699 times
Sorry for the bad pictures. Shiny black things are really hard to get good shots of.
dointhangs
Re: Han Solo trapped in Delrin?
Post by dointhangs » Thu Oct 04, 2012 4:30 am
Pretty cool but we really want is princess leia in a jabba slave costume.
No seriously great work pls say more about software? What did you use to get it to this point.
I just placed an order for a 1/8" ball end mill and you have me wishing I put in for a 1/16" also.
And also: is this 800mm/min in all dimensions, with the new z axis upgrade you are just leaving that a high number?
daveczrn
Post by daveczrn » Thu Oct 04, 2012 5:48 am
When your doing 3d milling you really want to keep the speeds and feeds the same on all three axis. It tends to give a smoother surface with less imperfections. Delrin you also want to run fast as it likes to push and not cut if you try to go slow.
CptanPanic
Post by CptanPanic » Thu Oct 04, 2012 10:52 am
Nice
Todd Bailey
Post by Todd Bailey » Thu Oct 04, 2012 12:44 pm
NIce!!!! May I ask where you got the model from or is that your work?
Todd Bailey and ShapeOko - 413
Owner and Creative Designer
4m3D Creative Design
http://www.4m3d.com
Skype Call - todd.4m3d
Phone - 443-450-4633
Newsletter - Subscribe - Free model every issue
Post by Improbable Construct » Thu Oct 04, 2012 3:31 pm
I am indeed running it at 800 mm/mn in all three axis. If I try it again I am going to bump the speed up and see what happens.
it was only cutting 0.00625" off per pass so speed should not be an issue.
The model came from Thingiverse.
http://www.thingiverse.com/thing:1274
I imported it into my CAM software and created a roughing path with a 1/4" end mill and a finishing path using a 1/16" ball nose mill.
Total running time just under 2 hours.
Todd Bailey
Post by Todd Bailey » Thu Oct 04, 2012 5:48 pm
Thanks for the link!!!!
http://www.4m3d.com
Post by cvoinescu » Thu Oct 04, 2012 9:28 pm
Very, very nice!
Now, purely for symmetry, I want carbonite V-wheels, idlers and lead nut for my ShapeOko. :D
Post by Improbable Construct » Thu Oct 04, 2012 10:03 pm
I ran another try of this today.
The larger one is the new one.
Han Solos.JPG (76.44 KiB) Viewed 3613 times
I ran this one with a zero degree raster path
It came out about the same as the first one but with out the visible corners from the offset path.
Todd Bailey
Post by Todd Bailey » Thu Oct 04, 2012 10:17 pm
Looks good!
You mentioned you ran a roughing pass... whats you method for changing cutters? or did you?
http://www.4m3d.com
