wagon vice - low profile workholding
polkadot
Post by polkadot » Wed Feb 08, 2017 2:01 am
I wanted to make a vice for my shapeoko, and decided that it would be fun to build it into the baseplate.
i started by milling the end of the slot that the shapeoko could reach, then removing the plate and finishing the carriage slot with a circular saw and a router with a slot cutting bit
after reassembly:
i cut the carriage on the mill from 7/8" aluminium plate to accommodate the 1/2" threaded rod with a little room to spare. the table itself is 5/8"
the threaded rod is retained by a simple end plate secured into the side of the baseplate
finished vice holding a piece of 2 1/4" square stock
the jaws are easily removed if i need to secure a larger piece of stock to the table, or replaced if i need taller or wider ones for a specific job.
thanks for checking it out!
SmokyRick
Re: wagon vice - low profile workholding
Post by SmokyRick » Wed Feb 08, 2017 2:31 pm
That looks very nice. You have come up with a great solution.
Smoky Rick Crawford in the middle of Northern Illinois, USA.
ShapeOko2 s/n 5200 all stock. Arduino, gshield, Grbl Controller, Autodesk Fusion 360.
Mods: Quiet cut spindle, grbl v0.9g w/ spindle control enabled.
graycon
Post by graycon » Thu Feb 09, 2017 4:55 pm
That is exceptionally nice looking!
JeromyReno
Post by JeromyReno » Thu Feb 09, 2017 6:30 pm
this is so bad ass!!
