How To: Engraved Plastic Signs (Trail Maps)
johnelle
Post by johnelle » Wed May 17, 2017 12:54 pm
I have a request for plastic trail maps to be posted by the local trails folks on particularly confusing trails. They described a green plastic engraved sign which I interpret to mean using a fairly fine bit on a piece of plastic with a green surface but white/black laminated lower layers. Since this is all volunteer cheaper is better and the plastic materials appear none too cheap. http://www.bfplasticsinc.com/pc_product ... 11D4A0CA1C
If anybody has done something like this could you clue me in on:
  1. Best supplies/supplier
  2. Approriate tool(s)
  3. Best technique
Seems like I will have to use a pretty fine v-bit (1mm? 2mm?) to letter paths/roads.
hatallica
Re: How To: Engraved Plastic Signs (Trail Maps)
Post by hatallica » Wed May 17, 2017 4:25 pm
Disclaimer: I do not have first-hand experience with the material described below. Forum user sgth0mas did a write-up on it linked here:
https://www.linkedin.com/pulse/machinin ... k-articles
The King ColorCore website shows the exact scenario that you describe. Towards the bottom of the page, they have downloadable links regarding tools and CNC engraving.
http://www.kingplastic.com/products/king-colorcore/
http://www.kingplastic.com/wp-content/u ... -Sheet.pdf
http://www.kingplastic.com/wp-content/u ... orCore.pdf
http://www.kingplastic.com/wp-content/u ... niques.pdf
Small pieces (up to 2 sq ft) can be found on the Inventables website:
https://www.inventables.com/technologie ... n-on-white
Larger pieces are available from various plastics retailers.
As a side note, the material that you linked indicated that it was for indoor use. The same company seems to have indoor/outdoor acrylic products (probably treated with UV inhibitors).
Shapeoko3 #1153
cozmicray
Post by cozmicray » Wed May 17, 2017 4:33 pm
May be better / cheaper to use clear acrylic / plexiglass
Engrave on reverse side
fill in lines with colors (paint) high lite
