Wasteboard project holes for M5 Inserts
amartinez
Post by amartinez » Sun Aug 20, 2017 5:21 am
Hi all,
This is my first project with the Shapeoko 3. I modified the DIY Shapeoko Wasteboard project available here:
http://docs.carbide3d.com/tutorials/project-wasteboard/ to use the M5 M5x10mm Interface Hex Socket Threaded Inserts purchased on Amazon: http://a.co/07EgvEi
The change was made to use the Clamp Set provided by Inventables: https://www.inventables.com/technologie ... 3d-carving
I just changed the radius of the holes to 0.177 on Carbide Create
Thanks Carbide ;)
The perfect hole for this Insert
Wasteboard upside down
Job finished... Using the clamp set
franazzo
Re: Wasteboard project holes for M5 Inserts
Post by franazzo » Tue Nov 14, 2017 5:44 am
Hi
Are you using an adapter for your makita trimmer?
amartinez
Post by amartinez » Sat Dec 23, 2017 6:56 pm
franazzo wrote:Hi
Hi, I'm using the adapter that came with the Shapeoko kit. The link for the adapter: https://shop.carbide3d.com/collections/ ... 9340264262
I purchased the collet for Makita from Elaire Corp: http://elairecorp.com/makitaroutercollets.html.
Regards,
