I need help with Mach3
will1384
Post by will1384 » Sat Mar 01, 2014 12:02 am
I had used Mach3 in the past with the first CNC router I had, but I was given all the numbers to enter into the mach3 motor tuning screen, but with the Shapeoko 2 I have been trying to do the math on my own.
I have a blue chinese CNC controller box that was made for a 6040 CNC mill, I got it used on eBay and fixed it up a bit, it uses TB6560 chips, installed on four separate driver cards.
What I want to do, is use the blue chinese CNC controller box with Mach3 to:
(1) CNC routing using only 3 drivers
(2) 3D printing, using the 4th driver to drive the extruder
But I can't even get Mach3 to cut anything correctively, it seams to move to far in the different axes, and then cut to small, I have Mach3 setup in inches, but I have tried in millimeters, I am using Cut2D to generate G-code in inches, the Shapeoko 2 does move in the direction of the keyboard arrow keys, and the TB6560 driver cards are set to 1/8 microstep.
Here is the math I have done, I am not good at math :?
----The Stepper Motor:
Steps Per Revolution 200
----Aluminum GT2 Pulley:
Teeth 20
Pitch 2mm
----GT2 Belting:
Width 6mm
Pitch 2mm
----Usefull Info:
1 Inch = 25.4mm
----M8x1.25 Threaded Rod:
1.25mm of travel for one rotation
20.32 Threads per inch
25.4mm / 1.25mm = 20.32 turns per inch
----X and Y Axis Math in Millimeters:
20 Teeth x 2mm Pitch = 40mm
200 Steps Per Revolution * 8 Microstepping = 1600
1600 / 40 = 40
40 Steps per mm
----X and Y Axis Math in Inches:
2mm = 0.0787402 inch
20 Teeth x 0.0787402 inch = 1.574804
1600 / 1.574804 = 1015.99945136
1015.999 Steps per Inch
----Z-Axis Math in Millimeters:
200 Steps Per Revolution * 8 Microstepping / 1.25mm Length of travel for one rotation
200 * 8 / 1.25 = 1280
1280 Steps per mm
----Z-Axis Math in Inches:
1600 * 20.32 turns per inch = 32512
will1384
Re: I need help with Mach3
Post by will1384 » Sat Mar 01, 2014 3:34 am
I tried LinuxCNC and now I wonder if my microstepping is set to 1/8
here is a screen shot
X and Y axis were set the same, I clamped a ruler to the makerslide and told LinuxCNC to move 1 inch, and adjusted the Leadscrew Pitch numbers until the CNC router moved about 1 inch from what I could see.
Brian
Post by Brian » Sat Mar 01, 2014 4:26 am
with 1/8 microstepping my shapeoko 2 is 1016 steps per in calculated. I have yet to take a dial gauge to it to confirm but its working nicely. Ill have to check mach when i get back to my shop for the z axis. What is your vel/accel? Those TB6560 are temperamental drivers from what I've found, don't like to be pushed very hard.
Brian
Shapeoko 2 #I have no idea
will1384
Post by will1384 » Sun Mar 02, 2014 2:23 am
I used LinuxCNC to test what Microstepping the drivers were set to, because there is no documentation :roll: , I made sure Microstepping was set to 8, and for "Leadscrew Pitch" I think I set it to 0.635, to get 1016 Steps / in, then used the "Test this Axis" to move the Axis one half inch and used a ruler to see if it was moving the correct amount, most of the time when I tested a dip switch setting it moved enough to hit the end stops, so I had to be careful, the drivers were not set to 8 Microstepping if this test works, also I found my Z-Axis driver dip switch was slightly melted and not working, I had used a hot-air rework station to fix the drivers and I guess I got to close to the dip switch, I was able to fix the dip switch.
I then tried Mach3 again, and it still acts strange, I think I am going to start from scratch on Mach3 and delete all the settings.
Brian
Post by Brian » Sun Mar 02, 2014 7:44 pm
id recommend stepping up to a dial gauge as opposed to a ruler, much more accurate. Mach 3 has a step per in calculator for use with a dial gauge.
Brian
will1384
Post by will1384 » Mon Mar 03, 2014 8:56 pm
Brian wrote:id recommend stepping up to a dial gauge as opposed to a ruler, much more accurate. Mach 3 has a step per in calculator for use with a dial gauge.
I have one on order now.
I found this page
RepRap Calculator3
http://calculator.josefprusa.cz/#steppers
And
Steps Per Unit Calculator spread sheet - I tried it with LibreOffice
http://www.machsupport.com/forum/index. ... ic=16315.0
Here are some screen captures from running the Steps Per Unit Calculator spread sheet.
X and Y axis
Z-Axis
I am going to delete the Mach3 configuration and start from scratch using the figures above.
will1384
Post by will1384 » Tue Mar 04, 2014 9:43 pm
Yep, deleting the Mach3 configuration helped, I am able to make it move 1 inch / 25.4mm in Mach3's "Axis Calibration".
