So can someone point me to a good Lowcost 3 axis controler to work with Mach3?
Has anyone use one of these controllers with Mach3?
http://www.ebay.com/itm/CNC-Router-3-Ax ... 51c690fc9f
What is the Best Low Cost?
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
Upgrades
Damin69's Build Log
Re: What is the Best Low Cost?
No recommendations on a controller to use with Mach3 from anyone?
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
Upgrades
Damin69's Build Log
I think you'll find that most of the low cost boards are Chinese TB6560 type. They will work but are not without issues. I have a blue 4 axis board and had some issues with microswitches not working, they also tend to be finicky about the signals they receive. Long and short they will work but you might not find anybody willing to recommend a particular board. You might check on CNCzone if any are recommended.
Ok what is a Board and controllers that someone can recommend?DanMc wrote:I think you'll find that most of the low cost boards are Chinese TB6560 type. They will work but are not without issues. I have a blue 4 axis board and had some issues with microswitches not working, they also tend to be finicky about the signals they receive. Long and short they will work but you might not find anybody willing to recommend a particular board. You might check on CNCzone if any are recommended.
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
Upgrades
Damin69's Build Log
[nitpicking] The PC running Mach3 is the controller. You are looking for motor drivers. [/nitpicking]
I can't recommend the Chinese TB6560-based products unless you're willing to spend some time fixing the design errors, and know what you're doing -- or if someone happens to know of one that's better than average. Improbable Construct posted about his board not long very ago, maybe you can find his post.
Ok how about a good breakout board and motor drivers?
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
Upgrades
Damin69's Build Log
I use a c10 bob. I also have the new c10s revision but I did not like the push terminals. I connwct the c10 to pc via parrallel port. I attached separate motor drivers to the c10, then nema 23s to motor driver. Love my set up but the learning curve os a bit higher bit worth it.
Shapeoko 2 Full Kit
Upgrades:
Makita RT0701C
Upgrades:
Makita RT0701C
