I'm running mach3 with a TB6600 4 axis control hooked up to nema 17s. All axis' jog perfectly but when I run a gcode from cambam or a mach3 wizard, it does not move down. It simply cuts at the surface no mater what my target depth and cut increments. Both DRO and display screen show its moving but it the stepper motor does not. X and Y axis work perfect.
My Z uses a 3/8"-12 acme screw with step set a 145 (guessing). I'm not near my machine right now so I'm not sure the exact number is. I got that number using axis calibration in mach3. Not sure if the maters but I am using a UC100 since I'm running 64 bit windows.
Any help would be appreciated.
