Why doesn't it work?
Re: Why doesn't it work?
Post by WillAdams » Fri Sep 04, 2015 9:12 pm
The OP doesn’t have a valid license (please pursue this matter w/ the person the machine was purchased from).
Why not try Linux CNC? This project started out w/ strong opensource roots.
Georgei
Post by Georgei » Fri Sep 04, 2015 9:22 pm
Opss. I missed that one.
Then yes. Give Linux CNC a go.
klaus
Post by klaus » Sat Sep 05, 2015 8:59 am
Thank you for advices,
I'll look into Linux CNC and consider to use it. Seems a bit heavy to get started: I'll have to install Ubuntu, CNC program, cam program, connect to the port and hope that the settings will be unchanged. Will I have to tune the system? The controller is Toshiba.
I'm green in CNC and I bought a ready to use machine from a guy that knew how to set it up. It works, but all the software is pirated (also Cam Bam). I asked him about codes and stuff, but he stopped answering my mails.
I learned how to generate g-codes and was getting familiar with mach3, boring to stop at the very first project.
Post by WillAdams » Sat Sep 05, 2015 12:19 pm
We do have a fully opensource software stack documented on the wiki — hopefully that will get you running again:
http://www.shapeoko.com/wiki/index.php/Software
Post by cvoinescu » Sat Sep 05, 2015 2:21 pm
You can get a good start without installing anything: boot from a live CD or USB stick, and you're straight in LinuxCNC, without messing with the installed OS on your computer. It's the best way to give LinuxCNC a try without committing to it.
klaus
Post by klaus » Tue Sep 08, 2015 6:01 am
Ok, there are many solutions and I will make it work at the end!
I will let you know
PS. I appreciate that a complex thing like cnc-programming is made possible to people with average technical skills like me
