SALES / MAKING A LIVING
Woodworker
Re: SALES / MAKING A LIVING
Post by Woodworker » Fri Dec 26, 2014 11:47 pm
Little Hands, what is your software process? I like the rounded outside corners. I do my corners with a rasp but my SO2 could be doing them while I did something else.
Little Hands
Post by Little Hands » Sat Dec 27, 2014 3:41 pm
cvoinescu, SO clone? What are the spec's and stuff...? Any different than the SO2? I am looking to build another machine. I have already put together a BOM's based on the SO2 with lots of custom/modified parts, still working on the electronics (little-g stuff etc.?).
Little Hands
Post by Little Hands » Sat Dec 27, 2014 3:52 pm
woodworker, I use Turbo Cad for my designs & drawings. I use Cam-Bam for my cam software. From cam I send the file thru UGS. Stock SO2 controller & electronics.
The outside rounded corners are cut when the part is cutout on the SO2, The face edges on the boxes are rounded with a hand held router (the "old fashion" way). Keep in mind, the "old fashion" way/tools are much faster than a tool change and the stress of the part flying off table after so much work has already been done...!
Forgot, the etching is done with a laser engraver, could be done on the SO2 ya know.
Post by cvoinescu » Sat Dec 27, 2014 5:18 pm
Little Hands wrote:cvoinescu, SO clone? What are the spec's and stuff...? Any different than the SO2? I am looking to build another machine. I have already put together a BOM's based on the SO2 with lots of custom/modified parts, still working on the electronics (little-g stuff etc.?).
eShapeoko (links to store, assembly instructions, part drawings). It improves on Shapeoko 1; it's different from Shapeoko 2, but I'd say roughly the same performance.
Woodworker
Post by Woodworker » Sat Dec 27, 2014 5:53 pm
Thanks LittleHands. I do all my boxes the old fashioned way, but I would like to be able to do with my SO2 if I wanted to. Thanks for the input I will probably put cambam on my need to buy list. There seems to be a lot of advantages to it.
Little Hands
Post by Little Hands » Sat Dec 27, 2014 8:48 pm
woodworker, Cam-Bam works for me: function, options & for the cost. You get 40 free uses (not days). There are vid's as intros. etc. Keep in mind there are many other options out there.
