Early Father's Day present
Post by WillAdams » Sat Jun 20, 2015 5:08 pm
Here:
http://www.shapeoko.com/wiki/index.php/ ... ocking.svg
More on it here: http://www.popularwoodworking.com/woodw ... tool-chest
Cut out of brass or some suitable material, engrave the dial w/ a V-bit and follow path and F-engrave for the text. Should be able to source suitable hardware at the hardware store. I would suggest sourcing the hardware first, you may need to adjust the size of the holes to match.
Added it to: http://www.shapeoko.com/wiki/index.php/List_of_Tools
Probably will make a page for it when I work out the hardware angle. Suggestions and comments welcome.
Re: Early Father's Day present
Post by WillAdams » Thu Jul 16, 2015 2:37 am
Sourced hardware, printed a prototype, began modifying the hardware (had to print a jig to notch one screwhead):
full resolution on the wiki: http://www.shapeoko.com/wiki/index.php/ ... totype.jpg
Woodworker
Post by Woodworker » Thu Jul 16, 2015 2:50 am
Very nice work. I may have to make a bigger one for my lathe work. I could do it in acrylic, that would work. Thanks for the idea and the follow through.
Bruce
Post by WillAdams » Thu Jul 16, 2015 3:59 am
thanks!
One other consideration, get two sets of hardware, one aluminum, one brass, that way you don't scratch the nice brass test fitting,
Post by WillAdams » Mon Sep 14, 2015 11:33 pm
A picture is worth a wiki page, right?
As noted on the wiki:
1/8" thick 6061-T6 alu. Plate[http://www.shapeoko.com/forum/viewtopic ... 731#p53729]
Feed 215mm
Depth 0.2mm
Plunge 27mm
Bits 1/8" 2 flute carbide and V-bit
Speed was probably 2 or 3 on the dial of my Makita.
Post by WillAdams » Tue Sep 15, 2015 1:48 am
Clean up the flashing, polish a bit, source a brass Chicago screw, trim off a #8-32 screw, file a divot in a #6-32 screw using a jig, add a knurled #6-32 thumb screw and assemble:
AnonymousPerson
Post by AnonymousPerson » Tue Sep 15, 2015 9:45 am
That looks awesome. :)
Post by WillAdams » Tue Sep 15, 2015 12:03 pm
One hole was slightly off for some reason (had to file it out to adjust), and I should have re-cut the half-mooon hole until it was all the way through (it was a bit awkward to clean up).
I also used a 60 degree V-bit, when the CAM paths were set up for 90....
One thing I'm wondering about is if one could intentionally fold up the flashing over the cut edge and get a smoother surface more easily....the machine would need to be really dialed in to consistently leave it behind though.
