It looks like my dimensions change when I go from inkscape to makercam? I drew my part in inkscape with a width of 4" and height of 2.25" ish. When you load it into makercam, it changes the dims to a 5" wide and a height of 2.75" ish?
Anyone else have that issue?
Inkscape to makercam dims off? - Change the preferences!
Re: Inkscape to makercam dims off?
Be sure to change the import settings in makercam when you import from inkscape SVG.
Goto Edit -> Edit Preferences -> change the top value from 72 to 90.
That'll fix it.
That'll fix it.
That is what I was looking for, thanks!
