Working on a diamond-circle-square tutorial
Post by WillAdams » Tue Apr 23, 2013 2:29 pm
Drawing stuff up in InkScape was straight-forward enough:
http://www.shapeoko.com/wiki/index.php/Inkscape
but I was put off a bit, when my nicely-stacked objects were wildly separated when I pulled them in to MakerCAM.
Is there some subtlety I'm not understanding here?
Althiels
Re: Working on a diamond-circle-square tutorial
Post by Althiels » Tue Apr 23, 2013 4:50 pm
I've had an issue with that sort of thing as well going from inkscape to Makercam and never found a good fix so I would be interested if anyone figures this out as well. I was doing text in the center of shapes and I always had to go back in Makercam and line things back up.
bjbsquared
Post by bjbsquared » Wed Apr 24, 2013 12:02 am
Did you convert your objects to paths?
Post by WillAdams » Wed Jun 26, 2013 12:00 pm
FWIW, I believe I've puzzled this out --- only the first object is placed in register, the balance are randomly placed, so if one wants everything nice and neat, then bring in only one object as a compound path (or whatever the equivalent terminology in InkScape is).
Has anyone else been trying this sort of thing for calibration? I've cut 3 of them so far, and it's been interesting to see the improvement in quality as the machine's rigidity has been improved:
http://www.shapeoko.com/wiki/index.php/ ... .2C_Square
bjbsquared
Post by bjbsquared » Wed Jun 26, 2013 12:38 pm
I have not had this issue with MakerCAM. Before I save from InkScape I make sure there are no groups and everything is a path:
Explode groups = cntrl+a (select all) , cntrl+shift+g (ungroup), repeat ungroup until status line says "No groups to ungroup in selection."
Make all objects a path = cntrl+a (select all) ,cntrl+shift+c (object to path) , repeat object to path until status line says "No objects to convert to path in selection."
Then I save it.
I'm working mainly on a Mac but have done this with a PC as well.
Hope this helps.
Post by WillAdams » Wed Jun 26, 2013 2:23 pm
Thanks, yeah, that'd be the InkScape way of make a compound path.
bjbsquared
Post by bjbsquared » Wed Jun 26, 2013 4:04 pm
:D Ok, getting the terminology down is half the battle I guess.
