What's happening to my "O's"?
etxbkst
Post by etxbkst » Mon Sep 02, 2013 3:26 pm
I am not sure what's going on here, but take a look at how MakerCAM calculates paths for the O's. I'm trying to do a pocket operation.
Screen Shot 2013-09-02 at 2.53.52 AM.png (259.39 KiB) Viewed 2042 times
Screen Shot 2013-09-02 at 2.50.35 AM.png (89.74 KiB) Viewed 2042 times
Re: What's happening to my "O's"?
Post by WillAdams » Mon Sep 02, 2013 3:43 pm
I suspect it's an issue w/ how thefont is put together --- probably the winding (path direction) isn't correct --- try correcting / changing that.
Let us know the name of the font you're using and post the SVG file.
etxbkst
Post by etxbkst » Mon Sep 02, 2013 3:51 pm
WillAdams wrote:I suspect it's an issue w/ how thefont is put together --- probably the winding (path direction) isn't correct --- try correcting / changing that.
You're right about the font. I just used Arial Black and I get an ok O when calculating paths. The font on the jacked up file is Belizio Bold. One more question... What is the difference between the blue and the green toolpaths?
etxbkst
Post by etxbkst » Mon Sep 02, 2013 3:53 pm
Also, I tried to upload the SVG, and I get an error saying that extension isn't allowed.
bjbsquared
Post by bjbsquared » Mon Sep 02, 2013 3:58 pm
Blue are Arc's and green is straight. They have different G code commands.
Also if your arcs look green your gcode file might be reaaaaaaly big.
Post by WillAdams » Mon Sep 02, 2013 4:58 pm
add .txt to the filename.
etxbkst
Post by etxbkst » Mon Sep 02, 2013 7:12 pm
WillAdams wrote:add .txt to the filename.
Attached.
0.svg.txt
(2.44 KiB) Downloaded 172 times
BC.svg.txt
(8.81 KiB) Downloaded 233 times
Post by WillAdams » Mon Sep 02, 2013 10:32 pm
Font Bureau is a good foundry so the problem would seem to be excessive deconstruction --- the second file has filled in counters --- fix that in Inkscape by selecting everything and choosing Path | Combine.
Post by WillAdams » Tue Sep 03, 2013 1:22 pm
Added a note about this sort of thing on the wiki:
please note that MakerCAM only imports the first path in register at the origin, successive paths are scattered about the canvas. If elements are out of place, combine them into a single path (in InkScape this is done by selecting the paths and choosing Path | Combine).
