Makercam throwing in random lines... why!? Newb here!
philIam
Post by philIam » Mon Aug 18, 2014 7:53 pm
Hey,
I'm trying to cut these holes out and everytime I upload my SVG which I generated in Tinkercad (I've successfully cut holes with tinkercad generated SVGs) I get the following picture with a boat load of paths criss crossing in and out!
Any help greatly appreciated! ThankS!
philIam
Re: Makercam throwing in random lines... why!? Newb here!
Post by philIam » Mon Aug 18, 2014 7:58 pm
Additional picture here!
Post by WillAdams » Mon Aug 18, 2014 8:40 pm
Please post the SVG.
You need to union things (and difference paths you want to be holes).
philIam
Post by philIam » Mon Aug 18, 2014 9:35 pm
says svg is not allowed.
So i have to group all my holes together before grouping into the plane piece?
Post by WillAdams » Mon Aug 18, 2014 10:08 pm
Rename the svg to .txt
The outline view in Inkscape needs to match what you want to cut in MakerCAM.
philIam
Post by philIam » Mon Aug 18, 2014 10:08 pm
I'm using tinkercad, its ok to download as svg then rename the svg to text then load into makercam?
philIam
Post by philIam » Mon Aug 18, 2014 10:10 pm
I tried that and it had the same result in makercam.
philIam
Post by philIam » Mon Aug 18, 2014 10:11 pm
Oh ok here it is
SectionCText.txt
(223.94 KiB) Downloaded 63 times
philIam
Post by philIam » Mon Aug 18, 2014 11:15 pm
Im just especially puzzled that I got tinkercad svg to work before and I cut with it.
Post by WillAdams » Tue Aug 19, 2014 1:19 am
You might want to try mentioning the inconsistent behaviour to the developers of TinkerCAD.
Looking at the outline view of the .svg file in Inkscape, it matches the appearance of the file in MakerCAM, so the problem is w/ the file itself.
Tried fixing it in InkScape, but didn't get far, so exported to a .pdf and opened it in Macromedia FreeHand. Looking at it there, the file is a mess, w/ circles and curves made up of hundreds of short line segments. I cleaned it up.
Attached.
SectionCText_revised-svg.txt
(4.64 KiB) Downloaded 67 times
Please note the filesize reduction.
