Makercam wont follow path on the letter "L"
Mrevoir
Post by Mrevoir » Fri Aug 22, 2014 5:59 pm
Im trying to set up a follow path operation on some text. It all works fine except the letter L and part of the number 4.
Mrevoir
Re: Makercam wont follow path on the letter "L"
Post by Mrevoir » Fri Aug 22, 2014 6:00 pm
The view from makercam
Post by WillAdams » Fri Aug 22, 2014 7:36 pm
Please post the SVG (you'll need to change the extension to .txt)
Woodworker
Post by Woodworker » Fri Aug 22, 2014 9:26 pm
I have had a similar problem with using the Hershey fonts extension. It would do everything but the straight vertical line on "d"s and "u"s. Went nuts for a few days and even started using p and flipping it as a d. I think I solved the problem by "ungrouping" the text an least once if not several times.
Mrevoir
Post by Mrevoir » Fri Aug 22, 2014 9:57 pm
I can't post the svg, currently at work. But now that you mention it, the text was grouped.
Woodworker
Post by Woodworker » Sat Aug 23, 2014 1:46 am
Mine was not deliberately grouped but it still had to be ungrouped. I found an obscure google reference.
Mrevoir
Post by Mrevoir » Sat Aug 23, 2014 2:32 am
Well I ungrouped everything and it didn't seem to make a difference. Here's the svg.
lee.txt
(7.42 KiB) Downloaded 188 times
Post by WillAdams » Sat Aug 23, 2014 3:09 am
Seems to be a bug where MakerCAM gets confused by points which are perfectly stacked on top of each other.
I split everything, joined it, and added some connecting paths and curves to keep that from happening:
lee-partkamdesign-svg.txt
(10.04 KiB) Downloaded 253 times
Mrevoir
Post by Mrevoir » Sat Aug 23, 2014 3:00 pm
Wow thanks! If its not too much trouble, may I ask how you did it? I've been playing with it all morning, to no avail. I tried "break apart" and it gives me the same problem.
Post by WillAdams » Sat Aug 23, 2014 3:35 pm
You have to take each problem letter, i.e., ``L'' and:
- break it apart into two separate paths
- at the junction of the top paths, move the bottom-most point of the vertical stroke up a tiny bit and the left-most point of the horizontal over to the right a tiny bit
- (optional) draw in a path which connects the two --- if you look at the SVG you'll see that I made it an arc
I processed the #4 similarly, so that the paths didn't cross --- please look at the .svg (you'll need to remove the .txt extension and restore the .svg).
