Makercam has a mind of its own!!
KRG
Post by KRG » Fri Aug 14, 2015 1:49 am
Why does Makercam decide at random to cut right through a letter in a Pocket Cut??? It does it every time I import the SVG file. I have made sure the everything has been saved Object to Path but it still happens. ANY suggestions appreciated. (Its really strange that it does it on the first "s' and not the second one.)
CastIrony
Re: Makercam has a mind of its own!!
Post by CastIrony » Fri Aug 14, 2015 4:48 am
TIme to change your name to Gibon I guess. :D
If you delete the first S, and then copy the second one over there, does it do the same thing?
Post by WillAdams » Fri Aug 14, 2015 11:28 am
Check to see if remaking the object in Inkscape will help.
Post the .svg file.
Or try F-engrave — which will look much nicer w/ a V-bit.
CastIrony
Post by CastIrony » Fri Aug 14, 2015 4:38 pm
Looking into it more, I think MakerCam uses the clockwise/counterclockwise direction of the curve to determine whether it's an inside edge or an outside edge. It's possible that whatever vector app you used to save your SVG made that S in the opposite direction from the others.
madhatter
Post by madhatter » Sat Aug 15, 2015 1:12 am
CastIrony wrote:Looking into it more, I think MakerCam uses the clockwise/counterclockwise direction of the curve to determine whether it's an inside edge or an outside edge. It's possible that whatever vector app you used to save your SVG made that S in the opposite direction from the others.
You know, now that you mention it, I remember having an issue with makercam inverting radiused corners on some squares. Someone (sorry, I'd give you the credit, but I'm on mobile and don't want to search) said to select all you lines in inkscape and select "Path" - "Combine". It MAY help, but it is not guaranteed.
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
KRG
Post by KRG » Sun Aug 16, 2015 12:58 am
[quote="WillAdams"]Check to see if remaking the object in Inkscape will help.
Post the .svg file.
Here is the file in txt format
Forumpost.txt
(79.34 KiB) Downloaded 130 times
Have tried redoing and still happens. Also happens in the Rich&Bev line.
KRG
Post by KRG » Sun Aug 16, 2015 1:04 am
Tried it. No go :(
KRG
Post by KRG » Sun Aug 16, 2015 1:05 am
Everything done was in Inkscape
Post by WillAdams » Mon Aug 17, 2015 12:13 am
Combined into a single path:
Forumpost_singlepath.svg.txt
(116.89 KiB) Downloaded 137 times
KRG
Post by KRG » Mon Aug 17, 2015 12:48 am
WillAdams wrote:Combined into a single path:
How do you do that Will?
