Makercam has a mind of its own!!
Re: Makercam has a mind of its own!!
Post by WillAdams » Mon Aug 17, 2015 1:08 am
First, select all the solid regions: Path: Union
Then select all the negative spaces: repeat Path: Union, set colour to white, bring to front, select all, Path: Difference
KRG
Post by KRG » Mon Aug 17, 2015 2:21 pm
I'll give that a try. The file you sent back to me, the "o" was corrected but now the top part of the "B" is corrupt. I'll give this a try when I return home next week. Thank you so much for your time and help.
Richard
KRG
Post by KRG » Mon Aug 31, 2015 2:20 am
WillAdams- I am trying F-engrave or F-vcarve as you suggested. I imported my file into it by opening it in Microsoft Paint then saving it as a Bitmap file. It worked. My question is when I save it in F-vcarve it saves it as a .cng file. Will Carbide Motion read that is is there another step I need to go through?
Post by WillAdams » Mon Aug 31, 2015 11:08 am
Not familiar w/ F-Vcarve.
When I use F-Engrave, it saves as a gcode file — check the file in a text editor?
KRG
Post by KRG » Wed Sep 02, 2015 9:49 pm
Will - I meant F-Engrave. I set up a test piece. When I save it to the desktop, it has a file extension of .cng. I opened it with WordPad and it appears to be Gcode. But when I try to run it through Carbide Motion, I get an error that says " Error line 76 multiple M codes". I looked and there is only one line that has any M codes (It is not line 76 if I just physically count them) but I find nothing else. I have included below, the first part of the Gcode where this is located. If I delete it in WordPad, will it save it in the original .ncg? And if so, which do I delete and which do I keep M5, M9, or M2 ??????
( Code generated by f-engrave-1.50.py )
( by Scorch - 2015 )
(Settings used in f-engrave when this file was created)
(Engrave Text:Richard Gibson )
(fengrave_set show_axis 1 )
(fengrave_set show_box 1 )
(fengrave_set show_thick 1 )
(fengrave_set flip 0 )
(fengrave_set mirror 0 )
(fengrave_set outer 1 )
(fengrave_set upper 1 )
(fengrave_set v_flop 0 )
(fengrave_set v_pplot 0 )
(fengrave_set inlay 0 )
(fengrave_set bmp_long 1 )
(fengrave_set var_dis 1 )
(fengrave_set ext_char 0 )
(fengrave_set useIMGsize 0 )
(fengrave_set no_comments 0 )
(fengrave_set arc_fit center )
(fengrave_set YSCALE 2.0 )
(fengrave_set XSCALE 100 )
(fengrave_set LSPACE 1.1 )
(fengrave_set CSPACE 25 )
(fengrave_set WSPACE 100 )
(fengrave_set TANGLE 0.0 )
(fengrave_set TRADIUS 0.0 )
(fengrave_set ZSAFE 0.25 )
(fengrave_set ZCUT -0.005 )
(fengrave_set STHICK 0.01 )
(fengrave_set origin Default )
(fengrave_set justify Center )
(fengrave_set units in )
(fengrave_set xorigin 0.0 )
(fengrave_set yorigin 0.0 )
(fengrave_set segarc 5.0 )
(fengrave_set accuracy 0.001 )
(fengrave_set FEED 5.0 )
(fengrave_set fontfile "Rio Oro.ttf" )
(fengrave_set H_CALC max_use )
(fengrave_set plotbox no_box )
(fengrave_set boxgap 0.25 )
(fengrave_set cut_type v-carve )
(fengrave_set bit_shape VBIT )
(fengrave_set v_bit_angle 90 )
(fengrave_set v_bit_dia 0.5 )
(fengrave_set v_drv_crner 135 )
(fengrave_set v_stp_crner 200 )
(fengrave_set v_step_len 0.01 )
(fengrave_set allowance 0.0 )
(fengrave_set v_max_cut -1.0 )
(fengrave_set v_rough_stk 0.0 )
(fengrave_set v_depth_lim 0.0 )
(fengrave_set v_check_all all )
(fengrave_set bmp_turnp minority )
(fengrave_set bmp_turds 2 )
(fengrave_set bmp_alpha 1 )
(fengrave_set bmp_optto 0.2 )
(fengrave_set fontdir "fonts" )
(fengrave_set gpre G17 G64 P0.003 M3 S3000 M7 )
(fengrave_set gpost M5 M9 M2 )
(fengrave_set imagefile "C:\Users\Richard/None" )
(fengrave_set input_type text )
(fengrave_set clean_dia .25 )
(fengrave_set clean_step 50 )
(fengrave_set clean_v 0.05 )
(fengrave_set clean_paths 1,1,0,0,1,0 )
(fengrave_set TCODE 082 105 099 104 097 114 100 032 010 071 105 )
(fengrave_set TCODE 098 115 111 110 010 )
( Fontfile: Rio Oro.ttf )
G90
G91.1
G20
G0 Z0.2500
G1 Z0.2500 F5.00 ( Set Feed Rate )
Post by WillAdams » Wed Sep 02, 2015 9:58 pm
Did you use a recent version of F-Engrave and configure it for Grbl?
KRG
Post by KRG » Wed Sep 02, 2015 10:25 pm
It is F-engrave 150 which seemed to be the current one on their site. I do not know how to configure it for GRBL. When I look in "Settings" I do see that it has M5 M9 M2 as the Gcode Postscript
Post by WillAdams » Wed Sep 02, 2015 11:25 pm
Look it up on the CAM page: http://www.shapeoko.com/wiki/index.php/CAM
Go to: http://www.shapeoko.com/wiki/index.php/ ... _with_GRBL
Select the “Disable Variables” check box in the F-Engrave Settings window
un-select the “Enable Arc Fitting” check box in the F-Engrave Settings window
Use F-Engrave version 1.34 or higher. 1.49 adds a new option to not emit comments which will help to make files fit w/in Grbl's line limit.[2]
