error:Expect command letter
oddbear3
Post by oddbear3 » Sat Oct 03, 2015 8:51 pm
Hi
I have made an nc file in makercam and import it to g-code universial sender ,when I push send I get e
Expect command letter error ,have read on this forum that a comma i the g-code could occur this.
Are there someone out there who could tell me how to solve this issue?
Another issue I have is that suddenly the Shapeoko 2 ,all the axis goes in oppsite direction,like they are inverted, but nothing are changed ,what parameters have to be checked,will be thankful for constructiv answers.
Re: error:Expect command letter
Post by WillAdams » Sat Oct 03, 2015 8:58 pm
Post the G-code. Usually this is caused by setting your locale to one which uses commas as a decimal separator and the CAM app erroneously doing so.
Direction of movement is controlled by the Invert Bits setting $3 for 0.9: http://www.shapeoko.com/wiki/index.php/Grbl#Invert_Bits
If you have trouble w/ it, dump your settings and post here and we’ll help you puzzle it out.
oddbear3
Post by oddbear3 » Sun Oct 04, 2015 4:19 pm
Here are the settings grbl 0.8
Switch $6= 252 solve invert direction problem
NC file is here
2mm_fresing_ytterkant.nc
(90.97 KiB) Downloaded 197 times
oddbear3
Post by oddbear3 » Sun Oct 04, 2015 4:29 pm
One question more ,when i push "return to zero" it goes to a total different "zero" than I set how could I change that? :?
Post by cvoinescu » Sun Oct 04, 2015 7:50 pm
You have some very long lines in that G-code file, and you're using GRBL 0.8. If I recall correctly, GRBL 0.8 has a limit of 50 characters per line, and a couple of lines in your file are longer than that. That can cause various errors (and even spectacularly incorrect cuts); the error you see is certainly one possibility. Manually trim a bunch of decimals from the long lines (using a text editor), or use one of the G-code senders that can shorten numbers for you (see the wiki for a list). Also, if you can, you should upgrade to GRBL 0.9, because it's better in many ways.
oddbear3
Post by oddbear3 » Mon Oct 05, 2015 12:51 pm
Hi
Could someone tell me how to download and install this program?
This is the solution for my isssue .
Have tested with 3 digits after comma then it work fine.
https://github.com/jhessig/metric-gcode-truncator
Please help,someone
Post by WillAdams » Mon Oct 05, 2015 1:11 pm
It's a Python program:
https://github.com/jhessig/metric-gcode ... runcate.py
First, download and install Python: https://www.python.org/
Then, open up a command prompt.
Then navigate to the directory where you've downloaded truncate.py
Then type python truncate.py
You might need to add the filename which you want processed in which case it'd be:
python truncate.py <myfile>.nc
Please note that for metric it's better to keep at least 4 digits, some calculations may require 5 decimals.
oddbear3
Post by oddbear3 » Mon Oct 05, 2015 6:22 pm
Thank you for good advise ,but is there a step by step turtorials to get this work.
My main issue is that when using mm as we prefer here in my country, MakerCam make alot of digits after comma (more than 4) and then I get Expect command letter error
Is there a good solution for change the.nc file before sending in Universial G-code Sender or will this be like this in MakerCam when we use mm???
Post by WillAdams » Mon Oct 05, 2015 7:03 pm
We have an FAQ on this: http://www.shapeoko.com/wiki/index.php/FAQ#MakerCAM
I just load the .nc file into SCITE (a text editor which understands Regular Expressions) and edit it there:
Find:
\(\.\d\d\d\d\d\)\d*
Replace:
\1
Try a JavaScript instead? http://www.shapeoko.com/forum/viewtopic ... 62&p=12345
oddbear3
Post by oddbear3 » Mon Oct 05, 2015 9:26 pm
THANK YOU Will Adams
Problem solved,and i use java script viewtopic.php?f=33&t=1562&p=12345
quick and easy
Thank you very much I`m very thankful :D
