Makercam distortion for ovals/curves
gracydesign
Post by gracydesign » Fri Oct 30, 2015 5:37 pm
I'm importing an illustrator SVG file into Makercam but its distorting the shape. Its only happening to ovals and curves (image attached). Ive used Makercam on other projects without curves and I had not experienced any issues. My preference are set to 72. Can anyone help me figure out whats going on?
Screen Shot 2015-10-30 at 10.15.41 AM.png (151.3 KiB) Viewed 1272 times
Re: Makercam distortion for ovals/curves
Post by WillAdams » Fri Oct 30, 2015 5:46 pm
Could you post the AI .svg? (add a .txt file extension to upload it here).
My suggestion would be to put a 1" square on it, save it as a .pdf, load that into Inkscape, then save out as a .svg. and load the Inkscape .svg into MakerCAM.
gracydesign
Post by gracydesign » Fri Oct 30, 2015 6:08 pm
thank you WillAdams for quick reply. attached is the file i posted was an example but Im also attaching the actual file I want to use. I will attempt the Inkscape workaround.
OVAL-2-FINAL.txt
actual file
(862 Bytes) Downloaded 138 times
Untitled-2.txt
sample file
(620 Bytes) Downloaded 60 times
gracydesign
Post by gracydesign » Sat Oct 31, 2015 2:54 pm
@WillAdams
The inkscape workaround suggestion works great! thank you so much for your help :D
