Req. for info.
Lookin4help
Req. for info.
Post by Lookin4help » Wed Oct 16, 2019 8:09 pm
I want to add a new tool to my Carbide Create inventory. I know how to do that, but I don't know how to answer the questions about the router bit. What I want to use is a CNC spoilerboard surfacing carbide tipped bit. It is a 3 wing 1/4 shank, 1 inch cut diameter, straight cut.
For tool diameter, I presume I use 1 inch
For flute lengthy, I am guessing that is the width of the carbide tipped cutting blade, which is 1/4 inch.
For angle (per side) - I haven't a clue what goes there.
For number of flutes, I presume this to be the number of cutting blades (wings) which is 3.
Last of all, I am using this on soft wood. What speeds and feeds should k be using. If I leave what is auto set it will take me 37 minutes to surface a 12.5 x 5 inch board. That seems like an excessive amount of time to me.
All this is being done with my Shapeoko XXL.
A novice offers his thanks for help!
Re: Req. for info.
Post by WillAdams » Mon Oct 21, 2019 2:46 am
Sounds correct. See: https://wiki.shapeoko.com/index.php/Car ... ding_Tools to confirm --- the Glossary may help as well: https://wiki.shapeoko.com/index.php/Glossary
