Need advice on an endmill.
chambrot
Post by chambrot » Tue Oct 14, 2014 7:29 pm
Hello,
I am looking for some advice on what endmill I need to
purchase.
I need to cut some 8mm - 10mm thick HDPE plastic like what
cutting boards are made of. I have been using a 1/8" 1-flute and 2-flute
endmill and it has worked out great, but I am looking for something a bit
thinner like a 1/16". There are some parts that I need to cut out that have
areas that are 2mm or smaller. I see there are endmills thinner than 2mm,
but they dont seem to be long enough.
Does this exists? If so, Is there
anything that you can recommend?
Thanks in advance,
Schruminator
Re: Need advice on an endmill.
Post by Schruminator » Tue Oct 14, 2014 9:35 pm
I have 1/32", single flute endmills (with an 1/8" shank), as well as a couple that are about 0.063" and 0.0938" diameter if I recall. I had issues with double flutes and plastic, so I've stuck with single flute and had decent success. You're right on the cutting length though, the 1/32" endmills have a LOC of about 0.1", the 0.063" have a LOC of about 0.2" and the 0.0938" has a LOC of 0.375" or so.
Long story short, it's going to be difficult to find endmills that small (2mm) with that long (10mm) of a length of cut (LOC). You'll either need to look into drill bits, finishing by hand, or finding a way to modify your design.
As I mentioned above, my 0.0938" diameter (about 2.4mm) has a LOC of 0.375" (~9.5mm), but I have never cut that deep, so I am not sure if it tapers some as you move up the endmill.
Good luck!
PS: Link to that final endmill http://www.ebay.com/itm/3-32-0938-singl ... 2337c626d6
